I have cleaned about a dozen items and I have yet to have anything other than a brownish red goop and most of mine does not rise to the surface; it collects on the bottom.
I have a large steel plate (flat iron) that I use for the anode ("positive node").
I suspect that the various colors are from the elements that make up the material used for anode. I haven't used anything else for the anode. When I do, I'll report any color change that might occur.
I suggest that you avoid breathing in the fumes that come off these technicolor solutions. It is not oxygen that you will be breathing. You also do not want to inhale the hydrogen that comes off the nice clean solutions either.
"Making Sawdust Safely" Dusty
