Cart for Special Purpose Tools
Do you have plans for your cart
Is there any way I can get plans for the cart? I would like to build one for my shop. Yours is just what I'm looking for as I have a small shop and need all the room I can get.
- robinson46176
The hardest part of designing special storage is that item/s that you haven't bought yet...
Sorry, no plans. I just sized it meet my needs and minimize waste from a 4x8 sheet of birch plywood. I included a few measurements in my original post.Do you have plans for your cart
If you have any questions though, I try to answer them.
Art in Western Pennsylvania
- shipwright
I started out by measuring the space available to store all this stuff. Once I knew that I just had to make it happen. This is probably the only configuration that would have got it all in but then one is all you need.
[ATTACH]8813[/ATTACH]
Paul M
Paul M
- DSCN0365.JPG (127.12 KiB) Viewed 23344 times
Here are a couple of additional photos of the cart being assembled. Hopefully, they will provide further insight into how it was put together.
[ATTACH]8814[/ATTACH]
[ATTACH]8815[/ATTACH]
[ATTACH]8816[/ATTACH]
[ATTACH]8817[/ATTACH]
- Cart6.jpg (198.59 KiB) Viewed 23313 times
- Cart7.jpg (220.01 KiB) Viewed 23315 times
- Cart8.jpg (216.05 KiB) Viewed 23313 times
- Cart9.jpg (215.67 KiB) Viewed 23312 times
Thanks Art, The additional pictures are a big help on how it's put together. I should be able to build one for my shop and adjust it to the size I need. I have a band saw, joiner, belt sander, and planer to put on it and lots of small thing to go in the drawers. Thanks again for sharing this fine project.
Another 'example' of a craftsman rather than a 'builder'. Adaptation and creativity are part of my definition.
- tom_k/mo
If you can hang loose a couple days, I've gotten permission from Art to draw up a set of plans for his cart, and will have them available for the forum to use.wingrider wrote:Thanks Art, The additional pictures are a big help on how it's put together. I should be able to build one for my shop and adjust it to the size I need. I have a band saw, joiner, belt sander, and planer to put on it and lots of small thing to go in the drawers. Thanks again for sharing this fine project.
- tom_k/mo
Thought I'd show the progress so far. Here's the SketchUp model so far, I've got most of the scenes with details and dimensions added. Still have to finish the details on the drawers and drawer installation. Pennview (Art) has been fantastic to work with.
[ATTACH]8830[/ATTACH]
- Compact_SPT_Cart.jpg (230.46 KiB) Viewed 23254 times
