kd6vpe wrote:dwevans,
What material did you use to build the drum. I had been wanting to build a sander for segmented ring flattening. I had recently got my lathe duplicator from SS and want to create a drum using Nick's method with the duplicator on cutting a perfect taper. Clamping the duplicator down and using the way tubes to keep everything straight. Also how did you attach the drum to the shaft?
I used Baltic Birch for the drum. I cut them all out with my router circle jig. I made a Jig to drill the holes in the center, then put them all on a 5/8" shaft and glued them together. 2 disks in from each end I put a pin through the shaft and cut notches in the disk to receive the pin. This keeps the drum from spinning free on the shaft. Once this was completed and dried, I mounted some sand paper on the bed of the thickness sander and raised the bed till it was in contact with the drum and sanded it smooth.
Doug
Shopsmith Mark V model 500 upgraded to a model 520, bandsaw, Belt Sander, Jointer, Dewalt DW735 planer, Sand Flee
