Personally from a safety standpoint, I would not drive the bandsaw and sander at the same time. That said a concern with welding the hubs together relates to misalignment of the shafts. If the shafts are misaligned and you connect them with a solid coupling (welded hubs) you may experience some vibrbrbrbrbrbration.]farley wrote:ok looking closer I think the only solution to my mini and spt setup is to have two spt hubs welded together.
does anyone see any problems with that?
also on a general note.
why does SS have different type of hubs. One 5 groove for the SPT and the other 4 groove for the the headstock.
please don't say to fit their coupler, because in looking at it, the coupler doesn't have to have a 5/4 groove if the headstock/spt didn't.
inquiring minds want to know.
mini is too mini for my 2 SPTs
Rob in San Diego
I am not planning on ever running both at the same time, especially for the seconds to slide the headstock over, not worth the risk.
I think the points of the vibrbrbrbrbrbration ;-) make sense and as suggested earlier, I'll try the hose idea. Should work.
Thanks for the insight of why a coupler and 5/4 groove.
Dusty I want to mount my belt sander also.
With the spider couplings---is there a little give so there isn't that possibility of welded metal to metal misalignment?
Love Joy Spider Coupler
There is a rubber like insert that fits between the 2 halfs that really dampens any vibration when aligned. You still want to align the half couplers as best you can. I use these Love Joy couplers for many of my fun projects as they do not break like the Shopsmith plastic couplers when slightly misaligned. Plus you can get the ID of either coupler in many different sizes which used the same insert.farley wrote: With the spider couplings---is there a little give so there isn't that possibility of welded metal to metal misalignment?
problem solved
Haven't gotten around getting the love joy and star washer yet.
A rigid coupler was too much vibration as suggested.
Couldn't easy find a rubber hose size.
So I cut up a SS coupler, used one side for each tool. Used the correct hub, one accessory style for one tool, one headstock for the other.
Put in taller allen screws to prevent movement of the coupler. There is enough grab of the coupler to run both tools. These tools do run at the lower speed so that good. There is enough space so when I slide the headstock from one tool to another there is a space so both tools don't run at the same time.
Interesting innovation. Curious how it will 'hold up'. I would still check out the lovejoy couplers. Another 'choice' is the OLD 10E/ER jig saw coupler.farley wrote:Haven't gotten around getting the love joy and star washer yet.
I thought that regular garden hose was either 1/2" or 5/8" ID.farley wrote:Haven't gotten around getting the love joy and star washer yet.
Rob in San Diego
SDSSmith wrote:I thought that regular garden hose was either 1/2" or 5/8" ID.
My guess would be he couldn't find a short 'piece'.
- Splinters N Chips
