Jointer Repair
- jcraigie
Anyone ever tried the "alunameld" type of stuff? It''s supposed to be really strong (30,000 #'s). It's a little pricey but not to bad if you look around. I have a cracked carriage that I'm going to try it on so I'll let you know what I come up with.
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
Jeff
thegovernor11
- Bronze Member
I have had good luck using products from http://www.aluminumrepair.com/ to weld aluminum parts. Even and plenty of heat on all parts is what is needed to get a good joint. advoid hot spots. You may need to groove the parts beening welded so there is room for the weld to set beteen the parts. There are Videos at the above web site. No everyone can be a welder.jcraigie wrote:Anyone ever tried the "alunameld" type of stuff? It''s supposed to be really strong (30,000 #'s). It's a little pricey but not to bad if you look around. I have a cracked carriage that I'm going to try it on so I'll let you know what I come up with.
Here are a couple attempts at adding photos I am not use to this version of windows photoshop. I will do gooder next time:D [ATTACH]16948[/ATTACH]
[ATTACH]16949[/ATTACH]
[ATTACH]16950[/ATTACH]
- JOINTER 003A.jpg (40.71 KiB) Viewed 1978 times
- JOINTER 4A.jpg (57.11 KiB) Viewed 1979 times
- jointer 002a.jpg (49.28 KiB) Viewed 1978 times
I think I would start by removing the nut/washers/springs that secure the infeed to the outfeed table. That will allow separating them so as to ascertain why there is no movement and avoid over stressing the adjustment parts.
Oooops! I was thinking of a different thread!
thegovernor11
- Bronze Member
brad_nalor
Cast iron is a bit trickier to weld but is possible using nickel rod to even brazing. The cast iron crack should first be V-ground to get the penetration. I would try nickel in this particular situation. The key is preheating the cast iron and on the cool down cycle after the weld, slow it down by keeping heat to it and at the same rate of the weld / bond joint. Epoxy on this type of repair is not a good idea. Epoxy on cast iron such as in a cracked engine block can work, but not at a mechanical fix point or stress area.
Welding cast iron
Here's an article in CarCraft about repairing a pair of cracks in an engine block. Might help
http://www.carcraft.com/techarticles/cc ... index.html
SS Mark V, 10" cabinet saw, 10" RAS, 8" jointer, 16"x 60" lathe, DP, 12" & 18" BS, Molding machine, 2 planers, belt/disk sander, numerous others.
- easterngray
