The reason for this is that you could damage the eccentric. Light taps are probably OK, but a hard blow could knock the eccentric out of alignment, and the set screw would score it.charlese wrote:Although I've read I'm not supposed to do this rapping while the tailstock is on the machine
Does morse taper need lube?
michaeltoc
Michael
