Everyone,
I must have confused. My question wonders the practical limits in using a planer to reduce the thickness of a board. Assume I start with a 1 inch thick board and want a 3/8 inch board. Does it make sense to plane away 5/8 inch to get to 3/8 inch? Does it make more sense to resaw?
I'm interested in what are people's thoughts in preferences in use of planer. Some might prefer to plane away out of a discomfort with resawing. Others might not want to plane down more than a certain amount to save the planer knives.
Maybe the planer is so efficient, that everyone would prefer the planer exclusively no matter how much thickness to remove.
I hope this is clearer.
Resaw versus Plane
A little clarity
Wm. D. Elliott
Dallas, TX
1972 Model 500; upgraded to Model 7; bandsaw; belt sander; joiner; planer pro; power stand; OPR; Biscuit joiner; router tables
Dallas, TX
michaeltoc
I don't see any practical limits to using a planer. I do see the limits of wasting wood. Generating 5/8" worth of sawdust is just that - sawdust. But resawing a 1" board in half and then planing to remove the bandsaw marks gives you an extra board to work with.wdelliott wrote:Everyone,
It's really a matter of personal preference. Planing is easy - just run the board through a few times and you're done. Resawing can be a PITA. There are too many factors that can spoil the cut: blade size, and tension, blade guide adjustment, freehanding or using a resaw fence to compensate for drift, etc. With practice, I can now get the bandsaw to make a pretty decent cut - so resawing would be my preferred method.
Michael
I wholeheartedly agree PROVIDED we are really talking about 1" stock. If the materials were purchased at a box store, those 1" boards are probably more like 3/4" in which case I would make a couple passes through the surface plane.michaeltoc wrote:I don't see any practical limits to using a planer. I do see the limits of wasting wood. Generating 5/8" worth of sawdust is just that - sawdust. But resawing a 1" board in half and then planing to remove the bandsaw marks gives you an extra board to work with.
- robinson46176
dusty wrote:I wholeheartedly agree PROVIDED we are really talking about 1" stock. If the materials were purchased at a box store, those 1" boards are probably more like 3/4" in which case I would make a couple passes through the surface plane.
Yes. It also make a big difference if it is odd piece of cottonwood or some $500 piece of imported unobtainum...
Aside from the chips vs usable cutoff, I consider the planer as only 'necessary' when common dimension(thickness) is needed for multiple pieces. Second to that is a need for parallel faces. Beyond that it is a matter of choice between options available/convenience.
