mortiser
scottss
Jim I was using a piece of pine the same size as the oak as a backer. I did the test cut in the pine then traded spots with the oak. The drill bit starts the cut but when the chisel makes contact I can't go any further it just flexes the motor back. I am afraid to continue this for fear of damaging the headstock or quill.
At this point from all that I have read here I can almost for sure say that there are only two things that can be the problem.
1) The chisel is not as sharp as it needs to be, so rehoning might help.
2) The wood is very very hard and the cure is to drill relief holes first, or select another method of making the cuts.
As good as any drill press mounted mortising pkg. is they do have limits and clearly when thing start bending you have reached them. If after attempting to rehone the chisel it still will not cut then another method should be selected. Using more force is not the correct direction to go.
