I noticed that when I was getting some pictures earlier.
The scroll saw can perform all the functions of the jigsaw, but while doing so more effectively. I assume with more "scroll saws" coming out, they needed to compete and didn't see a point in producing a lesser quality product at the same time. Shopsmith rarely produces 2 of the same tool (only things I can think of is table system 510 520 mark 7, and the planer/pro planer).lilgodwin wrote:Why did Shopsmith switch from Jigsaw to Scroll Saw?
Scroll saw hands down, larger table, better cuts, deeper throat. However, for the price of an older jigsaw, that can't be beat, they almost give em away with used shopsmiths.lilgodwin wrote:Which is is better overall? OR Which one is better for which applications?
For this reason, I must say is the only thoughts I could find for an advantage to the jigsaw. However, as I just spent somewhere around 18 hours on my scroll saw this week, I will say for accuracy I wouldn't even try what I did on a jigsaw, I needed the bigger table and throat. The accuracy and fine cuts were necessary. With the quick release on the scroll saw, fretwork is easier.lilgodwin wrote:What are the actual differences/advantages/disadvantages?
peterm wrote:farley
I like the SS jigsaw for it's ability to take files and stiff jig saw (saber saw) blades in the lower chuck with the upper arm removed, giving unlimited work piece size. I believe the SS scroll saw is better at cutting with a very fine blade.
I believe you are refering to a coping saw. And its about as close to a scroll saw as you can get for a hand tool. Held in by both sides, but I have yet to see a reversed tooth coping blade.JPG wrote:There has never been a hand held scroll saw(except the open frame hand tool version).![]()
Therein lies the source of the confusion. It is not preference, but misuse.Beave2012 wrote: . . .
Overall, the two terms are virtually interchangeable for most people (scroll saw/jig saw). So its all personal preference, but I would pay $200+ for a scroll saw vs a $50 jigsaw anyday. However if money was a big issue, a jigsaw will get it done as well.
True, a true scroll saw has 2 parallel arms supporting a constant tensioned blade used for cutting intricate shapes in the wood (scrolls).JPG wrote:Therein lies the source of the confusion. It is not preference, but misuse.Beave2012 wrote: . . .
