Rough cost of used Mark V 520?
Hi Patrick!, I'm Chuck!
Let me try to interpret our U.S. use of the King's English.;) Just Kidding, hey!!
I am sure Dusty intended to convey that a Mark V having an older 3/4 HP motor and a one bearing quill would not be as good of a deal as a used Mark V having a headstock with a 1 1/8 HP motor and a two bearing quill.
1 1/8 HP motors are in all units starting in 1962
Two bearing quills were added in 1984 (?).
reference: http://www.shopsmith.com/ownersite/toolhistory.htm
P.S. I love your part of the world. Have called square dances in Calgary and have a number of friends up there.
billmayo
Shopsmith
Post by billmayo »
charlese wrote:Hi Patrick!, I'm Chuck!
Let me try to interpret our U.S. use of the King's English.]http://www.shopsmith.com/ownersite/toolhistory.htm[/URL]
I find the 3/4 HP motor and smaller tables are as powerful as the 510 & 520 upgrades. If you have a 500 or a 510 Shopsmith, I still have a few 520 Pro tables with rails, 520 fences and 520 carriages I do not have the extension or floating tables with 520 rails. I have some of the 520 upgrade parts available. I hope to have a double bearing Gilmer & Poly-V quill assembly available soon.
Bill annbill.mayo@comcast,net
patrick_demets
Post by patrick_demets »
Charlese, thanks for your reply. So let me get this straight. Is a 520 (not an upgraded 500 or 510) always shipped with a 1-1/8HP motor and two-bearing quill? That would be my guess, since by my reading 520 was introduced in 1999.
patrick_demets wrote:Charlese, thanks for your reply. So let me get this straight. Is a 520 (not an upgraded 500 or 510) always shipped with a 1-1/8HP motor and two-bearing quill? That would be my guess, since by my reading 520 was introduced in 1999.
My name is not Charlese but maybe this will help - since I ad a part in creating this confusion.
Any of the older models can be upgraded to any of the newer configurations by simply adding and/or removing the appropriate parts. So a 500 of yesteryear could become a 520 of today.
If you buy new, you will get what is described in the literature for the model you purchase.
If you buy used, it is necessary to check closely to know what you are buying or have bought.
Likewise, you can go backward but I don't know why you would do that.
The following clip depicts the current models that can be purchased from Shopsmith.
Another cut at that same information expressed differently.
patrick_demets
Thank you Dusty and Chuck for that very helpful information. I'm looking at a lot of pictures from kijiji postings. I can recognize a 520 quite easily (with the red switch) -- only seen one of those recently. From just a front view of the headstock, can one say if it's a 500 or 510? I would imagine other characteristics (table size, etc) would allow an experienced eye to distinguish. I'll start seeing some in person tomorrow (yay!)
beeg
Post by beeg »
beeg wrote:The only difference between the 500,505,510,520's are the carriages and table size.
There is NO DIFFERENCE in the headstock between a 500,505,510 or a 520, all in the same era.
peterm
Post by peterm »
I note the dealer in Ontario has a 520 for $1800 CDN here:
http://allinonewood.com/?page=shop/flyp ... 531c12a6b&
Peter
patrick_demets
beeg wrote:There is NO DIFFERENCE in the headstock between a 500,505,510 or a 520, all in the same era.
Hi Beeg,
Maybe I'm not using the right terminology. Just by looking at the front part of the headstock (where the speed control is), can one tell from a picture what model it is? The 520 is most definitely different (the red switch is quite obvious); the others I can't tell. But then again, someone experienced might also clue in to the table size, color, etc.
Thanks for your comments,
Patrick
peterm
Post by peterm »
As beeg said, in any given year ("era") or on any production date you choose, all the SS models used the same headstock. All models of the year the the one you saw with a red switch was made, also had the red switch. They were all painted the same colour.
So to your question:"From just a front view of the headstock, can one say if it's a 500 or 510?" the answer is NO. The difference is revealed by the table rails and the fence.
Peter
I didn't see anyone list this link:
http://www.shopsmith.com/ownersite/faq/markv.htm
I'd go there for some help on what is what ie motor HP, color changes, headstock changes, introduction of new models etc.
If someone did post the link, sorry I missed it.
