What to look for in a "good" dado blade set and/or am I using it wrong?
If the set is designed like the ss one(left/right outer blades), reversing them would lead to rough cutting at the edges.
Cutters
I hesitate to ask this but did you put the correct cutting blades on the proper sides? One is to go on the left cutting side, then your chippers and then the right cutting blade. If you had them assembled in the wrong order that would account for some nasty chipout.
Mark V 520,Mark V 510(2),Mark V 500(2) Dust Collector(2), Jointer(2), bandsaw(2), jigsaw, beltsander, biscuit joiner(2) Lathe Duplicator, RingMaster, Pro planer
Thought I just said that!:)dan1999 wrote:I hesitate to ask this but did you put the correct cutting blades on the proper sides? One is to go on the left cutting side, then your chippers and then the right cutting blade. If you had them assembled in the wrong order that would account for some nasty chipout.
You bet! I was very upset because I had not used that set very much and the feed rate was slow and seemed to be fighting me for some reason! I think I turned red in embarrassment when I discovered what i did, and there was no one else around. Dumb mistake.JPG40504 wrote:Bet THAT slowed down the feed rate!:eek::D
Bill
