Will a 1/2" drill bit chuck fir on my model 510?
damagi
Post by damagi »
swampgator wrote:Al,
A Shopsmith chuck, which the linked Jacobs are made for will accept the 5/8" spindle and will accept up to 1/2" drill bit. I got one from eBay for about $10 plus some shipping. Cleaned it up and it work super.
Also, you can look on the Shopsmith website and compare what is on eBay. But, very often you can buy from Shopsmith directly at the same price or lower than a bid price on eBay. Some of those folks bidding just want it without realizing you can get it cheaper from Shopsmith. If the bid price is more than 1/2 what I can purchase it from Shopsmith, I'll just get it from Shopsmith. But, always voting with my pocketbook to when and what I can buy to bring my system up to par. Still have a few pieces to acquire. The aluminum sanding disk from the 10ER's will also fit the Mark V's. The best to you.:)
Fair warning that for some stuff, the reason for the higher price is because it could take 6mo to get your item. Things seem to be going faster now, but in the past year or two that was a good reason for the higher prices...supply and demand.
damagi AT gmail DOT com
wiredone
Post by wiredone »
I've been getting an average of $25.00 for them when I sell one.
There were several different types over the years, The best is the Jacobs That looks like this.
The number 3326 should be visible.
SS chk 2.jpg (139.73 KiB) Viewed 1313 times
www.wirewerkes.com
Hiding in a Joshua Tree.
awatson6 wrote:Do you see anything wrong with this chuck? http://www.ebay.com/itm/280739099784?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
That is a 'shopsmith' original. Though not made by jacobs, I have not heard any complaints about it.
The seller is reliable!!!!!! Never any 'junk'!
paulmcohen
Post by paulmcohen »
damagi wrote:Good call, you are correct. I never realized that the "tool support and shaft assembly" was a 1" to 3/4" adapter.
I have thought about using the 1" hole directly, is that what you are doing?
There are a lot of accessories that I would like that require a 1" post.
Paul Cohen
Beaverton, OR
air55plane
Shopsmith support
Post by air55plane »
For what it's worth, I buy from Shopsmith when I can. They are a relatively small company that has managed carefully to stay in business. In my opinion, the uniqueness of our machines requires support from time to time that cannot be found elsewhere. We need them/they need us. For those of you who have never talked to Shopsmith Customer Service, those folks are THE BEST, most courteous and helpful people anywhere. My opinion only, Tom
damagi
Post by damagi »
air55plane wrote:For what it's worth, I buy from Shopsmith when I can. They are a relatively small company that has managed carefully to stay in business. In my opinion, the uniqueness of our machines requires support from time to time that cannot be found elsewhere. We need them/they need us. For those of you who have never talked to Shopsmith Customer Service, those folks are THE BEST, most courteous and helpful people anywhere. My opinion only, Tom
Very true. One interesting difference I just learned is that sometimes there is an actual difference between what SS sells and what you might find locally. Apparently the SS strip sander belts are more flexible than most standard ones. As such, they are better for curved platten or non-platten work.
