Reclaimed Cypress
nate03031980
Born Again Heartwood Owner
Post by nate03031980 »
It was cool to find some of my wood on a forum. As I read the remarks I had to make some corrections.
All of our wood is river and lake recovered from South Carolina. We recover our logs from 1700 - 1800's mill-sites. Some of our logs were recovered from depths of 50 feet or more. These logs were growing when Christopher Columbus got here. Yes, you buy modern cypress for a cheap price about anywhere in the southeast. Modern cypress lumber comes from trees less than 50 years old with little to no heart. The growth ring count of modern cypress is less than 10 rings per inch and, at most, only 4-6 ring per inch.
Our logs are all virgin old-growth and ax-cut. The growth ring count in our cypress is a minimum of 20-40 rings per inch. Our logs are 95-100% heart wood. The river normally removes the little sapwood there is. The log in the picture above was only 32" on the small end. We have logs that are up to 60". The 60" log we have has over 800 growth rings not counting the sapwood which is missing.
Pecky in cypress is not caused by bugs or worms. It is caused by a fungus (Stereum taxoii), which works its way into the heart of the tree from the top and works its way down to the roots. This entire process takes decades. Once the tree was cut down and put in the river, the water killed the fungus leaving a Swiss cheese look.
nate03031980 wrote:It was cool to find some of my wood on a forum. As I read the remarks I had to make some corrections.
All of our wood is river and lake recovered from South Carolina. We recover our logs from 17 and 1800's mill-site's. Some of our logs were recovered from depths of feet or more. These logs were growing when Christopher Columbus got here. Yes, you buy modern cypress for a cheap price's about anywhere in the southeast. Modern cypress lumber come from tree's less then 50 years old with little to no heart. The growth ring count of modern cypress is less then rings per inch and in most only 4-6 ring per inch.
Our logs are all virgin old growth and ax-cut. The growth ring count in our cypress is a minimum of 20-40 rings per inch. Our logs are 95-100% heart wood. The river normally removes the little sapwood there is. The log in the picture above was only 32" on the small end. We have logs that are up to 60". The 60" log we have has over 800 growth rings not counting the sapwood which is missing.
Pecky in cypress in not caused by bugs or worms. It is caused by a fungus(Stereum taxodii) which works it's way into the heart of the tree from the top and works it's way down to the roots. This took decades. Once the tree was cut down and put in the river, the water killed the fungus leaving a Swiss cheese look.
This is one of the reasons I wish I was younger and more financially capable. I would be in your area, in a heart beat, to load up a trailer full of that lumber (maybe more than once).
You guys who are still young and able should really give this some serious thought.
beeg
Post by beeg »
Welcome Nate. Can ya explain why the logs were sunken and how ya find em?
nate03031980
Log recovering
In the 1800's, logs were rafted together and floated down the river to the mills. On the trip down the river a unknown percentage of these logs sank.
We us a side scam sonar high-definition tow fish along with diving to locate the sites. Diving in these black water rivers is not for the faint of heart. There are high currents, little to no visibility, falling trees under water, and gators. In South Carolina the law requires an Archaeological Survey to receive a licence to recover logs along with a couple other permits. Once all licence's and permit's are in hand the recovery begins. We use a custom built barge and 15 ton hydraulic winches to pull them up along with diving. It sounds easy on paper. Any way getting them to the surface is easier then getting them out of the water. Some logs weigh over 20,000 lbs.
nate03031980
Log recovering
beeg wrote:Welcome Nate. Can ya explain why the logs were sunken and how ya find em?
They became 'water logged' and sank?:rolleyes:
Am anxiously awaiting a response to the second ?:)
nate03031980
Most cypress were already water logged when they were cut down. It didn't take much time before becoming completely saturated.
wood 012.JPG (107.72 KiB) Viewed 2168 times
Ed in Tampa
Post by Ed in Tampa »
nate03031980 wrote:Image
Interesting I always thought bugs caused the pecky. I have found a lot of bug carcasses in the pecky. Of course they could have crawled in and died after the wood was cut.
All I know for sure is pecky cypress draws the termite guys like flies to a picnic, they just have to probe it with their ice pick termite finder.
Ed in Tampa
Stay out of trouble!
nate03031980 wrote:In the 1800's, logs were rafted together and floated down the river to the mills. On the trip down the river a unknown percentage of these logs sank.
I forgot to welcome you to the forum. I was too busy feeling sorry for myself because I can not come there to help you harvest lumber from the river bottoms.
Do your divers need special certification or is any qualified diver allowed to do this sort of "salvage dive".
nate03031980
I'm a commercial diver.
