You can download it from VintageMachinery.org 610 Magna 18" Jigsawhobbies wrote:i need one please maysw5454@gmail.com
Jig Saw 505644 Manual
Re: Jig Saw 505644 Manual
please send me a copy ofthe jig saw manuel. chuck schu @ mamashoe@cox.net
Does anyone have the manual showing the shopsmith part numbers for the 505644 jigsaw?
I can only find the MAGNA jigsaw manual online
Please email to: Paso907@bellsouth.net
Check your mail. I sent the back cover with the drawing and parts list.
The link given by rpd above has the 1965 Manual for the Jig Saw and includes the most recent part numbers. Introduced in 1954, this Jig Saw had very few changes over the years. Early Jig Saws had straight mounting posts which later changed to the eccentric mounting posts sometime between May of 1980 and July 1982. They are the same Eccentric Mounting Posts used by the Strip Sander. Near the end of their production or perhaps even after, a change to the Trunnion Bolt Assembly was made using a Socket Head Screw and Washer. This was to provide a more positive lock for the trunnion. The Jig Saw was discontinued in the very late 1980's. Very few if any new OEM parts are still available from Shopsmith.
nonnac1714
- Bronze Member
Im a new member , but I sure could use a copy of that manual for the 505644 model 610. Please email to ckcannon52@hotmail.com Thanks
rpd wrote: Sun Jan 31, 2016 1:58 amYou can download it from VintageMachinery.org 610 Magna 18" Jigsawhobbies wrote:i need one please maysw5454@gmail.com
nonnac1714,
Welcome to the Shopsmith Forum. At the link above provided by rpd you can download a PDF copy from Vintage Machinery. That is the easiest way to get a copy and even though the Manual there is from 1965 little changed on the Jig Saw during it production from the 1950's through the 1980's as I said above.
