Electrolysis Power Source
I have read that the reason you don't submerge any copper into the solution is because the copper reduces and deposits onto the "clean" iron piece causing it to now rust very quickly once removed from the solution.
I have previously been using a battery charger for my power supply, but have changed to using an old "bag" phone charger which supplies 13.6 volts and an untold amount of amps. It seems to be working fine.
Monte in Missouri
Two 1954 Mark V's: #268502 and #267199
My electrolysis results
I am finally getting around to restoring the bandsaw that I got with my Mk 5. The Mk 5 was stored inside and was in decent shape, but the bandsaw was stored in a not so enclosed shed. The cast iron table took the brunt of the exposure, and electrolysis seemed like the best way to restore it.
First of all, thank you to everyone who posted their experience with the process. Here are a few pics of my setup.
The electrodes are angle steel and are attached together with 12ga copper wire on the outside of the tub. I should have made them longer so they protruded over the top, as now I have to be careful not to over-fill. Instead of 'measure twice, cut once', I measured once and cut six times.
[ATTACH]8725[/ATTACH]
Somehow I forgot to take a good 'before' pic of the table, so this is the only one. The charger pictured ended up not working... more on that later.
[ATTACH]8724[/ATTACH]
This rig was built for the bandsaw table specifically, which is why there are more electrodes on one side.
[ATTACH]8726[/ATTACH]
The charger pictured did not work. I think it may have been broken before I started. Next I tried a 1.5A motorcycle maintainer type charger. It started working, but after a while it shut off with an error light. I tried hooking a battery inline as in PG-Zac's post, but I got the same result. In the charger's defense, I think the battery was too far gone to accept a charge. I went out and bought a new 2/4/6A charger that seemed to have less "intelligence" than the other one I tried. Success! I set it at 6A and let it run for about 4 hours.
I turned it off, disconnected the clamps, and pulled out the table. After a little scrubbing under water, a little sanding with 400 grit and a little more with emery cloth, it came out quite nice. A couple of coats of paste wax later, and here it is! Hmmm, the picture makes it look dirty still, but it is clean and smooth.
[ATTACH]8727[/ATTACH]
Overall I was happy with the process and the result. I bought baking soda, since I could not find washing soda. I did bake about a cup of it in an attempt to convert it to sodium carbonate. What I baked was not enough, so the solution ended up being a mix of the two.
Thanks again to everyone who shared their successes and failures. This is something I probably would not have tried if I only came across a document detailing the process.
--Loren
--Loren
- parts laid out.JPG (327.95 KiB) Viewed 7328 times
- empty.JPG (198.34 KiB) Viewed 7329 times
- put together.JPG (321.71 KiB) Viewed 7333 times
- result.JPG (295.32 KiB) Viewed 7336 times
Loren, you did a really neat job on your tank. By having the electrodes all the way around probably makes it much more efficient. I just used a steel plate so my process is very unidirectional.
Thanks for the feed back and for the photo images.
Mickyd informed us that this electrolyte we are using and copper are not compatible. I read that but I did not heed. Today, I put another of my rusty swivel caster into the electrolysis process.
Everything was the same except that I changed leads. The ones I used this time had copper alligator clips and I attached one of them to the rusty item and submerged it.
The resulting foam was the rest indication that something was different. It was a different color. But, the real difference became apparent when I removed the item from the solution a couple hours later. The deposit was nasty and the rusted item is not near as clean. I'll redo the process to see if I ruined a caster but---
DO NOT SUBMERGE COPPER INTO THE ELECTROLYSIS SOLUTION!!!!!
- tom_k/mo
I had an idea (brain fart?) and thought I'd throw it out for comment. Knowing that the electrolysis process is a "straight line" process and works best when there are electrodes on all sides of the object being treated... What if you took a 5 gallon metal bucket and used that as the container/tank AND electrode? I know you'd have to sand or sandblast any protective coating off the inside of the bucket, and you would have to be careful that your part was hanging/suspended in the solution and didn't touch the bottom, but it seems as if you'd get good current flow and rust removal on ALL sides equally and it would make wiring that electrode extremely easy.
Until the process eats a hole in the bucket and springs a leak...tom_k/mo wrote:I had an idea (brain fart?) and thought I'd throw it out for comment. Knowing that the electrolysis process is a "straight line" process and works best when there are electrodes on all sides of the object being treated... What if you took a 5 gallon metal bucket and used that as the container/tank AND electrode? I know you'd have to sand or sandblast any protective coating off the inside of the bucket, and you would have to be careful that your part was hanging/suspended in the solution and didn't touch the bottom, but it seems as if you'd get good current flow and rust removal on ALL sides equally and it would make wiring that electrode extremely easy.
Heath
Central Louisiana
Central Louisiana
Citrusstrip Dusty Citrusstrip Overnight Liberally applieddusty wrote:The carriage that was scheduled for electrolysis is an ebay special and it looks horrible. No corrosion. Just somehow stained and somewhat rusty (corroded).
It was to be an experimental restoration before I start on something more valuable.
[ATTACH]8699[/ATTACH] [ATTACH]8700[/ATTACH]
- mickyd
Your exactly right heath. The process WILL eventually eat a hole in the bucket. The bucket (anode....+ charge) is sacrificial.heathicus wrote:Until the process eats a hole in the bucket and springs a leak...
When I do it like this, I put the bucket inside a larger container that is filled with water. The reason I fill it with water is WHEN the inside sacrificial one (anode + charge) springs a leak, the water level won't drop.
Sunny San Diego
Sunny San Diego
While on the subject of things to not do, here a couple of additional things I've come across that one should avoid.
Don't use Stainless Steel as the anode attached to the positive lead as it contains chromium. The electrolysis process slowly erodes the chromium and the result is that chromates end up in your electrolyte. These are highly toxic. Yellow electrolyte is a sign of chromates. You'll end up with hazardous waste.
Stainless Steel also contains nickel and washing soda (sodium carbonate) can dissolve nickel and the resulting nickel carbide is extremely poisonous / toxic. Moreover, one should also not clean parts that contain nickel or that are nickel plated. All nickel compounds are toxic and some acutely poisonous. More hazardous waste.
Also the electrolysis process produces hydrogen and oxygen and therefore de-rusting should be done outside.
Art in Western Pennsylvania
