My First Attempt at Bowl Making
- fredsheldon
Mike,
Thanks for that link. I just sent a message requesting meeting times. They meet at the local Woodcrafters store about 10 miles from my house.
Fred
Fred
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
- fredsheldon
Now that's more like it. I purchased the grown up versions of the starter carbide tools at Woodcraft this afternoon. I finished up the 3 bowls that I had started yesterday this time using the new Full Size Version of the Easy Wood Tools and I must say there is a world of difference. I even gave the Bowl Gouge a shot after watching a bunch of YouTube videos all afternoon and think I finally have it figured out. I suspect I need to sharpen the gouge because the Carbide square cutter did a faster job of turning the inside of the bowls and created bigger shavings than the gouge. And I didn't have to worry about a snag. I'm going to attend the next woodworking club meeting here the third Saturday of the month and see if I can pick up some pointers on using the bowl gouge.
[ATTACH]22075[/ATTACH]
Momma and Papa and the little baby Easy Wood Tools
- 2013-07-05_18-24-51_519 (800x450).jpg (206.23 KiB) Viewed 13625 times
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
- fredsheldon
Storing Green Wood turning in bags
Once I turn bowls from green wood I pack them into paper bags with the shaving, label them with todays date and store them away for a few months. That makes 33 bowls I have turned since January, when I turned my first bowl. I have already given 2 away to wood providers and two more are going out soon to Heath and a Lady at work who also provided me with logs. The rest will be Christmas gifts for family members this year. I just might have enough to give one to each family member rather than just families as I had originally planned. I will need 38 bowls by the end of the year. I have run out of blanks and need to go on a search for a downed oak tree. Ha, that's a nice looking oak tree in the neighbors yard that just might get blown down in the next day or two
That's assuming I can get my winch to work.
[ATTACH]22100[/ATTACH]
Here are the bowls I turned today. And yes, I used my new Full Size Easy Wood Tools which made quick work on these bowls.
[ATTACH]22101[/ATTACH]
I take a handful of shavings and fill each bowl.
[ATTACH]22102[/ATTACH]
I add some shaving to the bottom of the bag, then pile some on top of the bowl once it's in the bag.
[ATTACH]22103[/ATTACH]
I then date each bag, fold the bag shut and store away for a few months.
- 2013-07-07_19-26-58_386 (800x450).jpg (241.45 KiB) Viewed 13672 times
- 2013-07-07_19-28-23_312 (800x450).jpg (268.37 KiB) Viewed 13675 times
- 2013-07-07_19-29-07_442 (800x450).jpg (256.34 KiB) Viewed 13672 times
- 2013-07-07_19-33-17_215 (800x450).jpg (271.59 KiB) Viewed 13697 times
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
fredsheldon wrote:[ATTACH]22103[/ATTACH]
AH BUT do you weigh the bowls?
- fredsheldon
Final Step, Turn Down Tenon
The final step to turning the bowls will be to remove the tenon and clean up and polish the bottom.
[ATTACH]22179[/ATTACH]
First I had to make a Jam Chuck to hold the work against the live center. I attached a 1 1/2 inch piece of red wood to a 6 inch face plate and trimmed round on the bandsaw. I then glued a 1/2 inch thick piece of foam and trimmed.
[ATTACH]22180[/ATTACH]
The Jam Chuck will fit a 6 inch bowl exactly.
[ATTACH]22181[/ATTACH]
For larger bowls you just center it as best as you can and apply pressure against the live center.
[ATTACH]22182[/ATTACH]
Center the tenon on the live center as best as you can.
[ATTACH]22183[/ATTACH]
Using your scrapers cut the tenon down to a nib, sand, apply sanding sealer, polish, remove from the lathe and sand down the remaining nib. Now I have 33 more bowls to finish up in this manner before I'm ready for Christmas.
- 2013-07-17_18-40-08_458 (800x450).jpg (212.39 KiB) Viewed 13711 times
- 2013-07-17_18-41-11_508 (800x450).jpg (190.8 KiB) Viewed 13717 times
- 2013-07-17_18-46-51_545 (800x450).jpg (216.05 KiB) Viewed 13713 times
- 2013-07-17_18-47-11_610 (800x450).jpg (235.5 KiB) Viewed 13719 times
- 2013-07-17_19-45-59_294 (800x450).jpg (176.93 KiB) Viewed 13715 times
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
- terrydowning
A sharp chisel also work wonders for taking out the nib.
My Process when using a Jam Chuck
Once the remaining is down to about what Fred shows, maybe a bit more material, because this narrow can break.
First I remove the remaining nib with a razor saw
Then I use a sharp chisel to smooth the nib portion flat
Last but not least touch up the finish.
Great Job Fred, Thanks for continuing this thread. It's great to see your progress.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
- fredsheldon
Finished at Last. Ready for Christmas
I finished turning down the tenons and polishing the bottoms of the last 8 bowls in this batch. I'm finished for now and have 34 bowls available for distribution as Christmas presents this year. All I need to do is figure out how to sign and date them. Any suggestons? I have learned a lot in the 6 months since I started this hobby and some of these bowls reflect that learning curve. I have a new supply of logs coming my way next week so I will be starting on the next batch.
[ATTACH]22291[/ATTACH]
[ATTACH]22292[/ATTACH]
[ATTACH]22293[/ATTACH]
[ATTACH]22295[/ATTACH]
[ATTACH]22294[/ATTACH]
- DSC_0508 (800x531).jpg (305.77 KiB) Viewed 13644 times
- DSC_0509 (800x531).jpg (319.41 KiB) Viewed 13650 times
- DSC_0510 (800x531).jpg (304.45 KiB) Viewed 13643 times
- DSC_0511 (800x531).jpg (297.29 KiB) Viewed 13642 times
- DSC_0512 (800x531).jpg (310.67 KiB) Viewed 13641 times
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
- terrydowning
The bowls look great Fred! Good to have Christmas out of the way??
I use a fine tip sharpie to put my name, date, and any specific instructions on the bottom. I usually do this before applying the finish to the bottom so it get sealed in.
Here is my latest. A bowl from an oak board.
[ATTACH]22296[/ATTACH]
I have also seen wood burning and stamps, some kind of maker's mark.
I can only suggest what I do for signing.fredsheldon wrote:All I need to do is figure out how to sign and date them. Any suggestons?
- 2013-07-25 19.42.50.jpg (55.1 KiB) Viewed 13632 times
Terry
Terry
There is A LOT of information in this post...thanks for sharing the pictures, it answered a lot of questions I've had about turning bowls...joedw00 wrote:Wow that it a lot of bowls. Nice job on all of them. Thanks for posting.
Now you've got me thinking of turning bowls instead of building furniture parts..."so-much-sawdust,-so-little-time"...
