Main Table Alignment to the Blade
Do you consider table to blade alignment something to be avoided?
Poll ended at Wed Dec 25, 2013 7:15 am
I have no strong opinions on this matter. I'll do whatever is necessary.
9
15%
28
46%
6
10%
4
7%
14
23%
Total votes: 61
[quote="JPG40504"]Well said!:cool:
I assume conclusions re the unanticipated 'discovery' will eventually surface?]
Probably not unless that Table and Tie Bar Assembly is moved back to either the Shorty or the GoTo machine.
The way it acts, I have concluded that the vertical supports are not parallel (for whatever reason). I could push those tapered pins and reassemble the Tie Bar Assy but why. It would just be my luck to break the tie bar.
