skou
Post by skou »
Yes, it's an early Mk VII.
steve
10 ER, stripped down.
thunderbirdbat
Post by thunderbirdbat »
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
Is that an over arm pin router to the right in the second picture?
br549
Re: Heads Up - Bargain 'available' - Planer $75
Post by br549 »
https://imperial.craigslist.org/tls/d/s ... 91248.html
Only one picture, not much of a description, but might be a good buy for someone near NW California.
EDIT: Changed price in post title, since CL ad has been changed so that price listed in ad title is now $75, not $40, even though tag in picture still says $40. If in decent shape, could still be a bargain at $75. Have sent a reply to seller asking for more pictures, more description about condition, etc.
thunderbirdbat
It looks like it. It reminds me of a picture from an ad for a 510 and OPR from Jan. Maybe he sold the OPR and still needs to sell the 510.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
GeorgeM wrote:Advertised as a Mark 5, but I believe it's a Mark VII
https://hudsonvalley.craigslist.org/tls ... 04500.html
George
Yep! Looks good from the back side!
roy_okc
Post by roy_okc »
Mark VII with jointer and belt sander for $175 in Tulsa area: https://tulsa.craigslist.org/tls/d/in-o ... 53821.html
510 with jointer, scroll saw, band saw for $625; no pics of floating tables, common accessories. Also Tulsa area: https://tulsa.craigslist.org/tls/d/shop ... 04932.html
Roy
CNCed G0704 milling machine
Laser engraver
The VII is a steal considering it's excellent condition(it all appears to be there including stuff that typically isn't).
br549
Post by br549 »
br549 wrote:https://imperial.craigslist.org/tls/d/s ... 91248.html
I did get a reply from seller, who says the price change in ad was in response to low-ball offers. He also offered the following information about its condition:
"...The story on the planer is as follows. It is operational. The blades are in fair condition. It has a motorized feed . The bad news is that it is put together backwards. I bought my shopsmith along with the accessories from a guy in Redding. The feed motor has a sticker from a shop in Redding that works on Shopsmiths sometimes. Nobody knows why its put together backwards. There are two problems with backwards operation (feeding boards into the out shoot ). If you want to use dust collection, the dust collection port is in the wrong place. Also there is a special tool for adjusting the blades. It cannot be used with things put together backwards. Another problem is the the feed roller doesn’t seem to have enough traction to move the boards all the way through without some assistance. Other than all that it works great. Seriously you can use it to plane boards and the last time I put new blades in I didn’t have any trouble adjusting blade height..."
I asked again for more pictures in order to understand how it could be put together backwards, but so far nothing received and no change to ad. I suppose if feed motor and cutter head were installed backwards, that would explain it, but why would someone do that? If it could be done, then I suppose it could be un-done. And if so, it may still be a good buy for someone willing to put in the effort.
thunderbirdbat
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
