PowerPro in 10 years
Ed in Tampa
Post by Ed in Tampa »
donalexander wrote:My thoughts exactly. I went to a demonstration at Lowe's and left without being tempted to spend the bucks on the unit. I really hope this doesn't come across as sour grapes because it isn't. I just simple don't see that there's nearly enough value in the upgrade to warrant the price of the upgrade. The key points I heard at the Lowe's demo were:
-It easier to set the speed on the PP. My thought was okay but the Mark V isn't hard enough to set that I've ever once considered it in 30 years of owning a Mark V.
-The PP starts with fewer amps. To which I though, I've got my Mark V on separate circuit and never worry about starting amps. A non-issue for me.
- The PP can go faster and slower than a Mark V. Well slower may have some advantages with the lathe but it hasn't been an issue with me yet. Higher speeds make the router and shaper possible. I bought a dedicated router with three different router bodies and a nice table for < 25% of the cost of the PP upgrade. I don't need a Mark V/VII router. To use the router effectively you really need the double tilt option and that's $389 more.
- The motor won't bog down doing heavy cuts. This hasn't been a problem for me yet. I'm not sure I've ever cut more than 8/4 lumber and that's rare. Usually 4/4 and 5/4. I'd be inclined to get a cabinet saw (3 HP or more) if I was doing lots of heavy cuts.
I realize a lot of wood tool snobs look down on the Mark V with disdain. That's a mixed blessing. It keeps the Craigslist prices low but frankly the Mark V is one heck of a good machine. It is capable of far greater accuracy that I am and they are certainly both durable and fixable. For the average person wanting to do wood working, it's a great tool that will let you build everything from bird houses to fine furniture without a hitch - as long as you have the skills.
What does the Power Pro add to the capabilities of the Mark V? Well, some power, ease of use, reversible motor, and greater speed range. Its worth $300 more than the Model 520 - which is what the difference is between a new PP and a new 520. I just don't see where the value is that justifies a $1,500 to $2,000 upgrade.
So, when I see a PP on Craigslist for $500 or less, I may go shopping. Until then I plan to make sawdust with my 520...or my 500...or maybe there's an ER-10 in my future.
What Donalexander has said about the Power Pro is what I have been trying to say only when I said it I usually ended up with some of you sore at me.
The only real advantage I see to the Power Pro is a having a rebuilt headstock, one that has fewer moving parts. However after hearing some of the problems with loose couplers which I think will manifest in other ways I'm not sure it is more reliable.
Over the life of my SS I have caused it to suffer lockups and some real off balance poundings. While I can not detect any damage I still wonder what may be on the verge of breaking. So a headstock rebuilt is very appealing to me. If I could get the PowerPro upgrade for a few hundred more than a normal Headstock upgrade I would jump on it in a minute. I have also considered buying a new PowerPro headstock and parting my old headstock out to see how close I come price wise.
However I will probably do as Donalexander wait until I see a $500 Power Pro on Craigslist.
Ed in Tampa
Stay out of trouble!
fjimp
Post by fjimp »
Gosh Ed,
By then your hearing may be gone and the extreme quiet of the power pro will be lost on you all together. I understand your reluctance yet a few months ago had my Power Pro unit set up for dado cutting on a project and decided to use my 50th anniversary 520 alternately as a drill press, and a table saw for several long rip cuts. By the end of the day I was truly thankful for the flexibility of speed and especially how quiet the Power Pro is. Oddly enough I truly appreciate the many things the power Pro does better and not feeling the need to use hearing protectors when I use it. Please sir do not misunderstand me, you are entiteled to your opinions I generally value your offerings and your fine way of presenting yourself. On this one point we differ and I am eternally grateful I was able to afford the upgrade when I did so. Would I upgrade the 50th anniversary headstock, no way I bought that machine for the historical significance and will not mess with it. On the subject of repair and alignment issues. I have experienced more issues with the old style head stocks and feel issues for those still outnumber those which have been disclosed on the newer model. Once again we are each entitled to our own impressions and I appreciate hearing yours. Keep up the good work. Jim
F. Jim Parks
Lakewood, Colorado:)
Ed in Tampa
fjimp wrote:Gosh Ed,
Jim
Thanks I likewise respect and enjoy your comments and contributions to the forum. I always apppreciate your input.
And thanks for not telling me to go soak my head as many have when I don't get all limp and gushy over the Power Pro.
Ed in Tampa
fjimp
Post by fjimp »
Ed in Tampa wrote:Jim
Thanks I likewise respect and enjoy your comments and contributions to the forum. I always appreciate your input.
Hey a good head soaking might be a pleasure here given current temp of 101 degrees. Jim
F. Jim Parks
fredsheldon
Post by fredsheldon »
Once I retire I'm sure I will have a completely different outlook on what to purchase and what not to purchase based on the "I've got to have the latest and greatest upgrades" rather than "Do I really need this upgrade or can I get along without it". That's why I have embarked on a buying spree for all the toys I want to have to enjoy during my retirement years while I still have additional income to allow me the ability to pay for them :D
I'm sure once my income is reduced to SS and Interest income from my investments I will have a compeletly different outlook on my puchasing needs.
That's when I will be setting up a booth at the local swap meets and sell custom made pens and letter openers that I made on my PowerPro SS :D
Fred Sheldon
The Woodlands, Tx
fjimp
Post by fjimp »
fredsheldon wrote:Once I retire I'm sure I will have a completely different outlook on what to purchase and what not to purchase based on the "I've got to have the latest and greatest upgrades" rather than "Do I really need this upgrade or can I get along without it". That's why I have embarked on a buying spree for all the toys I want to have to enjoy during my retirement years while I still have additional income to allow me the ability to pay for them :D
Great plan. I also invested heavily in my hobby over the last five years leading up to retirement. Now that retirement is about happen my spending has come to a halt. But now I hopefully get to enjoy the fruits of my spree. Jim
F. Jim Parks
paulmcohen
Post by paulmcohen »
donalexander wrote:So, when I see a PP on Craigslist for $500 or less, I may go shopping. Until then I plan to make sawdust with my 520...or my 500...or maybe there's an ER-10 in my future.
By the time you sell all the extra bits after the DIY upgrade the cost is not far from $500 especially if you got it a Lowes.
Paul Cohen
Beaverton, OR
paulmcohen wrote:I put on all the decals, where exactly is the serial number?
I'll snap a pic tomorrow. NEXT DAY -- Sorry! will try again to remember.
O.K. Paul - I remembered!:) The serial No. decal was attached to the larger decal, so I didn't try to separate them - If I could have.
[ATTACH]17854[/ATTACH]
[ATTACH]17855[/ATTACH]
[ATTACH]17856[/ATTACH]
paulmcohen
I have the same sticker but mine is completely blank in the important part.
[ATTACH]17863[/ATTACH]
Paul Cohen
Beaverton, OR
