Back side/inside of PowerPro control panel?
damagi
Post by damagi »
JPG40504 wrote:The Teknatool does not have a 'confirm' button???:confused:
The nova DVR has 8 Buttons on its front panel:
On
Off
Up RPM
Down RPM
Fwd/Rev
*Mode
*Selector
*Program
The Shopsmith has 13 (8 plus the extra 5 speed settings)
On
Off
Up RPM
Down RPM
Fwd/Rev
*Confirm
*Lock
*Chart
*900
*1350
*2000
*3450
*9500
The remote has 3 buttons I think:
Up RPM
Down RPM
On/Off
damagi AT gmail DOT com
Does the confirm button need to be depressed if the speed was set manually by the operator rather than the internal look up function?
nuhobby
Post by nuhobby »
JPG40504 wrote:Does the confirm button need to be depressed if the speed was set manually by the operator rather than the internal look up function?
There is a threshold of something like 1350 rpm. If you select a higher speed than that, either by the computer-chart or by using manual arrows, then you'll be asked to Confirm prior to running. So, for instance, a table-saw 3450rpm needs a Confirm every time you start.
Chris
fjimp
Post by fjimp »
nuhobby wrote:There is a threshold of something like 1350 rpm. If you select a higher speed than that, either by the computer-chart or by using manual arrows, then you'll be asked to Confirm prior to running. So, for instance, a table-saw 3450rpm needs a Confirm every time you start.
I agree with the above: Confirmation is required for all changes.
F. Jim Parks
Lakewood, Colorado:)
wa2crk
Post by wa2crk »
Yes the confirm button must be depressed every time that you press start and the speed setting is over 1500 RPM. Also the confirm button must be depressed every time that start is depressed regardless of speed setting when set to reverse. The 1500 RPM speed setting is very tight. 1500 is go and 1501 is no go unless confirmed.
paulmcohen
Post by paulmcohen »
wa2crk wrote:JPG
I think the question is if I set the machine to 1,200 RPM and then press increase can I increase all the way to 10K without hitting confirm. I think the answer is yes.
The limitation with the remote would be to start the machine over 1,500 without hitting confirm on the main panel. I don't see that as an issue.
I would get remote start for bandsaw where I really want it, remote stop for everything and the ability to change speeds remotely.
Paul Cohen
Beaverton, OR
paulmcohen wrote:I think the question is if I set the machine to 1,200 RPM and then press increase can I increase all the way to 10K without hitting confirm. I think the answer is yes.
Thanks y'all!
The confirm 'issue' has to do with the lack of that function for the teknatrol remote etc.
Sorta defeats the purpose of a wrist mount remote control to have to also push a main panel button.;)
Yes using slower spt's might work!:cool:
wa2crk
Post by wa2crk »
Paulmcohen
If the machine is running the speed can be increased using the up and down arrows. Once the machine is stopped and then restarted then confirm must be pressed again.
damagi
Post by damagi »
wa2crk wrote:Paulmcohen
Right - so while remote start wouldn't necessarily work, speed up/down and remote stop would still work...still useful.
wa2crk
Post by wa2crk »
damagi wrote:Right - so while remote start wouldn't necessarily work, speed up/down and remote stop would still work...still useful.
To a degree I suppose.
