I just purchased and used some of the Durham's. (Form the big orange box store) $8 for a 4 pound can. It does not take much water to activate this stuff and get it to a workable paste.
Pros:
It tools beautifully
It sands easily when dry
It sets very quickly (10-15 minutes until it can be sanded)
Relatively low cost
No shrinkage that I can tell.
Con:
It SETS very quickly! Even in a sealed container!:eek: It's not like other powders where you can mix a batch, leave it in a sealed container and come back to it later. I wasted probably 1/2 pound or more.
The can does not provide detailed formula for mixing, so you have to be comfortable with mixing to desired consistency, I like a warm peanut butter consistency for spread-ability.
Advice:
Read and follow the directions and only mix what you can use in a session. This includes a dinner or lunch break. I mixed up a batch and started patching, was called in for dinner, when I came out from dinner (30 minutes?) the remaining batch in the sealed container was "Rock Hard". Fortunately it popped right out of the plastic container I was using. But was mostly waste.
Work in small batches, a scoop or 2 with a putty knife into your container with just a little bit of water 1 oz or so? at a time.
Good stuff though, glad I saw it here and picked some up.
Wood Filler
- terrydowning
I have used it both with bare wood and to repair painted or stained wood. Always, always always mix less than you expect to use. It mixes quickly so no reason to waste it. Jim
F. Jim Parks
Lakewood, Colorado:)
FWIW, it does not dry, it sets!
Think chemical reaction triggered by water.
I sure wish I was smart enough to always use proper terms. Then again I would never have passed a chemistry exam. Thank for the lesson. JimJPG40504 wrote:FWIW, it does not dry, it sets!
F. Jim Parks
- terrydowning
Thanks, post edited.JPG40504 wrote:FWIW, it does not dry, it sets!
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
- robinson46176
It sets first then it dries...
