Simple Maintenance avoids Major Problems
IMO, absolutely nothing. I guess there are different methods to accomplish almost everything. If it works, don't change it.trainguytom wrote:All this talk of set screws coming loose...I've never had it happen.
Am I the only one who uses a drop of threadlock to secure them? Not the permanant-never get them out stuff, just the medium strength stuff.
Here's why I do it. It keeps the arbors from loosening up, I don't have to crank the screws tight enough to strip stuff, and in all the years I've done it, it's never hurt anything. So, what am I missing?
Remember, the set screw really doesn't hold the arbor on the shaft. The tapered shaft does that. The set screw just prevents the arbor from moving up and off the taper.
Your thread lock simply prevents the set screw from backing out of the way of the taper.
