shopsmith model id???
jdxprs wrote:376894
that number???
Late 1961, last number on chart is listed as 373422 so can you check your number again?
jdxprs
Post by jdxprs »
reible wrote:Late 1961, last number on chart is listed as 373422 so can you check your number again?
you're talking about the serial number right?
jdxprs
Post by jdxprs »
jdxprs wrote:you're talking about the serial number right?
Yes. See:
http://www.shopsmith.com/ownersite/faq/markv.htm
jdxprs
Post by jdxprs »
what does it mean if my number is not on that chart?
My 1963 Goldie is 'not on the list' either. The 'historical' records inherited by SS Inc. were incomplete. I am 'away' so I cannot check on my sn until Wed.
A rip fence is 'missing'.
A drive center is missing.
Cannot see the tailstock to see what may be missing there.
A drill chuck?
A sanding disc?
A saw blade and arbor?
All common items on e-bay!
jdxprs
Post by jdxprs »
JPG40504 wrote:My 1963 Goldie is 'not on the list' either. The 'historical' records inherited by SS Inc. were incomplete. I am 'away' so I cannot check on my sn until Wed.
A drill chuck?
A sanding disc?
there is just an open circle where the tailstock should be. what is a drive center? sorry if that's a stupid question.
jdxprs
Post by jdxprs »
i do have a saw blade.
The attached chart is from 1976, this was the standard equipment that came with my machine.
I don't have such a chart for your era of machine but perhaps this will help identify items for you and perhaps someone can advise as to what things came with your vintage.
[ATTACH]19092[/ATTACH]
std attach.jpg (65.48 KiB) Viewed 2339 times
mikelst
Post by mikelst »
For a reference manual to the greenie era shopsmiths look at this link
http://www.songofthegreatlakes.com/ssm5manual.htm
While there are some differences most of the info is still applicable to you.
You can look at the standard attachments breakdown on page 5.
see above...
Hope that helps
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
