That might work. The problem is that unlike most threaded adjustments, here you have to wind up in one position, 6 o'clock straddling the pistol grip, so you only get multiples of 1 turn. Maybe one or two of those little shim washers?
At any rate, I can't use it, since the stud will not fit the hole in the T-slot miter bar that comes with the table upgrade.
Newbie question
solicitr wrote:Mranum: one changed "detail" which might make a difference for you is that on early Greenies (up to sometime in 1955) there is no access hole in the back of the headstock, under the SS nameplate. As a practical matter, this makes routine maintenance something more of a hassle.
Thank you I did not know that.
