Jointer teardown and cleanup
Do not be surprised that evaporust will 'remove' the black oxide on the cutter head.
And do tell us what they measured!:)wa2crk wrote:If you have a set of calipers or can borrow one just measure the bearings (ID, OD and thickness) and use a search function on one of several websites and match the bearings. I use VXB at www.VXB.com and I get excellent service.
- pieceseeker
OD: 1.125" / 28.59mmJPG40504 wrote:And do tell us what they measured!:)
ID: .497" / 12.65mm
Width (thickness) : .311" / 7.90mm
- pieceseeker
[quote="JPG40504"]Do not be surprised that evaporust will 'remove' the black oxide on the cutter head.]
Thanks, I'll be wary of that when I get to that point.
I'll have to google that and see how tough that coating is.
BTW, do you already have personal experience with this "phenomenon" (just wanted to see if I could spell it)?
I use the R8Z bearing in this size. 1/2" X 1 1/8" X 5/16"pieceseeker wrote:OD: 1.125" / 28.59mm
ID: .497" / 12.65mm
pieceseeker wrote:Thanks, I'll be wary of that when I get to that point.
Evaporust does not care what color the rust is. Black oxide is rust.
Yes I have created non black parts from black oxided ones.
Do realize the bearings need to be self aligning(not 'regular' ball bearings).billmayo wrote:I use the R8Z bearing in this size. 1/2" X 1 1/8" X 5/16"
- pieceseeker
Well, finally got my new bearings for the cutter head on the jointer.
But first had to deal with the rust on the cutter head. Evapo rusted it and sure enough all the blackening came off. I was forewarned.
Luckily, Eastwood Company offers a blackening solution, so I decided to experiment.
I was satisfied with the results. Did a few other rusty parts while I was at it.
[ATTACH]21012[/ATTACH]
Tapped the new bearings on.
[ATTACH]21013[/ATTACH]
[ATTACH]21014[/ATTACH]
Tapped on the bearing caps (I guess they could be called bearing pillow blocks)
[ATTACH]21015[/ATTACH]
Also received my dust chute retro kit for the jointer.
[ATTACH]21016[/ATTACH]
So this week I'll start final cleanup and waxing of the painted portions of the jointer body and reassembly.
I see this week's email special is the dial indicator for aligning table to saw and jointer and planer knife alignment.
Guess I'll have to get one of those too!
- Cutter head blackening.jpg (144.5 KiB) Viewed 3402 times
- Cutter head with bearings.jpg (74.45 KiB) Viewed 3401 times
- Cutter head with bearings 2.jpg (85.65 KiB) Viewed 3402 times
- Cutter head with bearing caps.jpg (120.42 KiB) Viewed 3402 times
- Dust Chute retro kit.jpg (123.74 KiB) Viewed 3402 times
