upgrade to Power Pro or not?
chuckoliver wrote:The local motor repair shop reported the motor ran fine, but was full of dust. They cleaned it and replaced the bearings for a nominal fee, while I checked out the power cord. It turns out the white lead had opened right at the strain relief. It was not visible without removing the cord, and explains why I had no power at the on-off switch. My guess is the burnt smell I sensed when the motor stopped was the final few strands of the white lead heating up and melting open.
I cut of the bad section of power cord, reamed out the power lead hole for a new strain relief and reinstalled everything after cleaning out some gunk and oiling the mechanical parts. Both drive belts were in apparent good condition so I didn't replace them. I'm back in business.
Thanks to all who comments and my apologies to the folks who wanted to live vicariously through me, if I upgraded.
I have not said this before but I will now. If a person is going to own and maintain a shop with power tools, one if the tools in the shop should be a multimeter. They are simple to use and simple to learn to use if you don't already know how. A quick ohm meter check on the power cord (while still attached to the Mark 5/V) would have indicated the possibility of either a bad cord or switch.
The indication would not be absolute as motor windings could have been open and that would be another story.
chuckoliver
Upgrade to Power Pro or not
Post by chuckoliver »
I concur with Dusty regarding the multimeter. Sears has adequate ones for under $20. Radio Shack is probably a good source too.
Actually, I had determined there was no power to the switch, but with the motor installed, I couldn't see how it was wired. After I pulled the motor, I didn't test it, but figured it couldn't hurt to have it looked at by a shop and possibly replace the bearings as PM. The motor came back looking and running like new. It was only after close inspection that I found the open in the power cord at the strain relief.
And if that is too 'complicated', there are continuity lights.(or a flashlight and two wires:D)
shealyl
Post by shealyl »
I upgraded to a power pro and love it. So much better than the orginal. Soft start, more power, quieter, easier to control. Go for it.
