Wow - interesting thought. When I lived up in Port Townsend WA about 20+ years ago, there was a wooden boat building school up there and they had big wood steamers that you could put long boards into and then after steaming, bend and contort into the desired shape - obviously overkill for this project but your idea reminded me of that. I'll havew to ponder how to make the jig but I like your idea and there's really not much to lose in giving it a try.johnheyd wrote:I remember in high school shop a lot of guys were making toboggans out of oak and they heated the ends of wood slats in boiling water for a period of time, then put then in a jig were they bent them. After then cooled they held that shape. So my thought is perhaps if you have an old turkey fryer, try boiling a redwood plank for about four hours - then clamp it into a jig to form the shape - let it cool and I'll bet you would have a curved form.
Birdfeeder Construction Advice
'82 Mark V 500 #96309
I was thinking the same thing - the correct diameter ABS or schedule 40 PVC, with ratcheting straps around it to bend the wood to that profile and clamp it until it dries...definitely worth a try. Fortunately around me finding some salvaged tight-grain clear redwood is fairly easy to do.danscot wrote:I wonder if a heavy gauge plastic drain pipe would give you the desired inside radius for this?
Anyone paying attention to grain direction?:D
I can understand toboggan strip bending, but creating cupping?
Perhaps a hexagonal shape... two sides glass four sides wood.
That's all flat sides just angles to worry about.
Or one side glass.. the side facing the ornithologist's kitchen window.
Bruce
Ok Ok, I'm up to four now...
