How do I make a 45deg bevel cut on my MK V safely?
sled2 Click to see.
Ah very good JPG.
Your link would be better. I was thinking of making that jig/sled but moving the fence back to accommodate wider stock. I like the idea of using the feather board that I already have. No need to hunt down a toggle clamp.
1986 Mark V 500, SS Bandsaw, SS Belt Sander, Shaper Package, SS Molder, SS Oscillating Drum Sander, Excalibur EX-II scrollsaw, Central Machine 6 1/8" Jointer, Rigid 13" planer, Various routers and table.
"Remeber, you're unique. Just like everyone else."
TheBigE wrote:Ah very good JPG.Your link would be better. I was thinking of making that jig/sled but moving the fence back to accommodate wider stock. I like the idea of using the feather board that I already have. No need to hunt down a toggle clamp.
Sled3 Somehow:rolleyes: this got sidelined.
judaspre1982
reluctant43
This is a very professional looking picture you posted. Do you have a plan? How would you modify this to make raised panels, for example?anmius wrote:I suggest using a 45 degree bevel sled if you are going to do a number of cross-cut miter cuts. Not a difficult jig to make but much safer than trying to catch a cut-off before it hits the shop floor.
[ATTACH]22307[/ATTACH]
reluctant43 wrote:This is a very professional looking picture you posted. Do you have a plan? How would you modify this to make raised panels, for example?
Yes I do have the plans that I picked off the internet. They are for a "45 degree bevel sled":[ATTACH]22616[/ATTACH]
If I was going to use something like this for raised panels, I think a different kind of sled would work better line this one: [ATTACH]22617[/ATTACH]
Bevel Miter Sled 45 Degrees.pdf- (79.1 KiB) Downloaded 1181 times
RAISED PANEL TABLE SAW JIG.pdf- (109.68 KiB) Downloaded 1904 times
Abraham Lincoln
Abraham Lincoln
I'd be interested in seeing some pictures of this set-up. Either here, a new thread, or by email. Thank you.anmius wrote:This is precisely why I use a Sliding Compound Miter Saw which I clamp on to the Shopsmith table and use the "outrigger" Extension Tables for support. I can cut up to a 16' board with very little difficulty. For longer boards (like clapboard siding), I add additional out-feed rollers as support. The Shopsmith makes an excellent Miter Saw Stand (albeit a little more expensive than one from Dewalt).
New Leaf Custom Woodworking
I'm out of town for a while so I'll take some pictures when I return and post them.berry wrote:I'd be interested in seeing some pictures of this set-up. Either here, a new thread, or by email. Thank you.
Abraham Lincoln
Abraham Lincoln
I'm back in town so here is the promised picture:
[ATTACH]22706[/ATTACH]
Here it is with a 10' piece of poplar that I need to cut to length for rails and stiles to make a kitchen cabinet door. My SCMS is just clamped to the Shopsmith table and the outrigger tables are adjusted to provide support. Very simple and very easy.
If you have any questions, please feel free to ask.
- SCMS on Shopsmith.jpg (64.24 KiB) Viewed 4828 times
Abraham Lincoln
Abraham Lincoln
Too Late! Shopsmith already did it:) and discontinued it:(.dragginbutt wrote:Wow, I had not thought of that. I purchased a cheap table top table saw just for those times I needed a bevel cut. I can see a bunch of guys filing quick patents for new accessory for this with some sort of adjustable angle that can be locked at various angles. OK all you engineers, get busy... I'll buy one
