OK! Problem solved! Incorrect cant was the problem.billmayo wrote:If the upper wheel needs to be canted more, I recommend removing the upper wheel and use a 18" to 24" snug pipe on the axle to bend the arm. Do not push or pull on the upper bandsaw wheel. I have a few examples of someone getting carried away doing this. I have been unable to take out all the twists from some wheels as these wheel twists do effect the blade tracking.
Following Bill's pipe advice and JPG40504 directions in a previous thread, I corrected the cant and 1/8" blade tracks fine now.
- With a straight edge laid against the upper wheel, the straight edge should clear the top of the lower wheel by about 1/4".
If there is no clearance: - removing the upper wheel
- use 18" to 24" snug pipe on the axle to bend the arm
- my finished clearance is about 3/8"
- does not take a lot of torque to bend the flat casting
go slow to avoid over correcting
does not matter how you bend the cast arm, just protect the axle
Thanks so much,
Dan
