Flexible shop light
benush26
Post by benush26 »
beeg wrote:Did ya call a hazmat team for cleanup?
:eek:
No, though at one time I did have a HAZMAT cert., worked at a Superfund and was a construction supervisor. First occurrence (never thought there would be a second!!) :eek:, inquired about handling and disposal of it and was told that the quantity of hazardous materials was small enough that could have been added to the waste stream without concern.
Not the answer you were expecting?? :D
I've worn WAY too may hats in my life!
Be well,
Ben
wrmnfzy
Post by wrmnfzy »
ashbury wrote:wrmnfzy, returning to the original post, don't ignore the task lighting in the big box stores in the grill and BBQ accessory sections. Many of these feature clip on as well as mounting with rare earth magnets in their bases. Most of them are of the LED variety and very flexible. I use one mounted to my Dewalt jig saw, the other shares positions on the bandsaw, strip sander and lathe.
I'll check there also, thanks.
anmius
Post by anmius »
How about something like this from Rockler:
http://www.rockler.com/mag-flex-led-wor ... -dual-base
Abraham Lincoln
Ed in Tampa
Post by Ed in Tampa »
My opinion and you all know how cheap I am. The Shopsmith light on sale is worth it. I have two and will buy two more the next sale.
If you have ever used a cheap light you know they get hot as heck after awhile from the light blub. The SS has a massive heat sink and keeps the light below raise an instant blister from heat point.
I switched it over to a CFL and that is even better. Number on light on the work bench. Number one light on bandsaw, planer and miter saw. That is why I need two more.
Ed in Tampa
Stay out of trouble!
dgale
Post by dgale »
Mike907 wrote:If you are near an Ikea store, you can try these -http://www.ikea.com/us/en/catalog/products/20169658/. No clamps or magnets, but the base is weighted, and they are inexpensive. The woodturners here just duct tape them to their lathes. We have no Ikea store, so whenever a club member travels, they fill a suitcase with them on their way back.
The same IKEA light is also available with a clamp for $5 more:
http://www.ikea.com/us/en/catalog/products/80169636/
'82 Mark V 500 #96309
wrmnfzy
Post by wrmnfzy »
I'm going to try, this and when the SS light comes up on sale I will most probably get one. Used my headlamp today and it worked OK.
Super High Intensity Magnetic Base LED Light
Focus on projects with this high-intensity workbench light. Super bright LED provide superb lighting. A strong magnetic base with 40 lbs. holding power secures the light to metal surfaces. The 8" flexible arm adjusts to your needs, weather-resistant aluminum construction ensures long-lasting use, and a wide illumination area results in a brighter workspace. Can also be used as a reading light, auto repair light, plumber's worklight, etc. Convenient on/off switch. Batteries included.
Features:
Super High Intensity Bright LED for excellent illumination
Zoom function up to x2000 to enable concentrated light to small areas or distributed light to wide areas.
Super Strong magnetic base: 40 lbs. holding power
Flexible 8" arm for easy adjustment as needed
Includes 3 AAA batteries
joedw00
Post by joedw00 »
I have two of the shopsmith lights with extra brackets. They are great and easy too move around.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
rlkeeney
Post by rlkeeney »
I was just thinking about these seconds before I saw your post. You could mount most any small flashlight in one of these. Some of them will put out more light than you coulds possibly use.
[ATTACH]24070[/ATTACH]
A quick Google search found a bunch of other possibilities.
I'm a big fan of the clamp on lamps and have several of them. They are cheap and use cheap standard bulbs that are available in just about any type you want. They are available just about anywhere for around $5.
[ATTACH]24071[/ATTACH]
Clamp On Lamp.jpg (54.6 KiB) Viewed 6165 times
robinson46176
Post by robinson46176 »
Based upon many of the TV remodeling and house buying shows there should be a huge abundance of used track lighting available to install in workshops. :rolleyes:
One of my many annoyances with such shows is the constant use of the word "dated" about everything and a near panic from some almost complete simpleton that the counters are not granite, the appliances are not all stainless steel (which BTW I read is now becoming "dated" and falling from favor) and god forbid a million dollar house has a couple of feet of track lighting somewhere in it... :eek: :rolleyes:
Far too many young couples that have NEVER had to do without ANYTHING in their lives. The concept of starting at the bottom and working their way up is completely alien to them.
Our kids grew up getting everything they needed but NEVER everything they wanted... Even what they needed was worked for...
Sorry... I was not watching where I was going and tripped over a soapbox... :rolleyes: :D :o
Anywho, I am going to be watching yard sales for a little track lighting for a few spots in the shop. :)
Simpleton. I had almost forgotten that word. I shall try to remedy that.
Speaking of which, which one(s) came out with the idea of stone tile floors and granite counter tops for a kitchen wherein much fragile dishware resides?:eek:
So 'we' go around setting things down 'carefully' so as to not break them in our hands.:D
Almost as stupid as neckties!!!!!!!!!!!!!!!:mad:
