The Corners Don't Fit
Some years ago I built a miter jack. Works really well with a well tuned plane. If your saw blade is close, this will zero it in to 45 degrees.
[ATTACH]24140[/ATTACH]
[ATTACH]24141[/ATTACH]
- 2013-02-25_16-08-05_312 (Mobile).jpg (55.37 KiB) Viewed 4375 times
- 2013-02-25_16-10-03_338 (Mobile).jpg (63.23 KiB) Viewed 4375 times
WmZiggy
williamz@aol.com
williamz@aol.com
Fred Grover
- terrydowning
- shipwright
Fred Grover
Wonder no more.
Some would consider it close enough.algale wrote:Wonder how many thousandths of an inch that 0.2 degree error amounts to per cut.
[ATTACH]24144[/ATTACH]
- .2 degree gap.png (26.83 KiB) Viewed 4357 times
- BuckeyeDennis
The original post was the result of a .2° in each of eight miter cuts that would be required to form a box. The pieces were jointed together (in Sketchup), one corner at a time, forcing the error to accumulate at the last joint.
Purpose being to show that this is not the best way to fit together the pieces. Tiny error accumulates. This is a lesson that I learned recently while trying to build some items for one of the kids. These were items that I wanted to be as perfect as I could make them. I did not do so well.
I posted this image in response to a question from BuckeyeDennis. It only vaguely relates to the other images in this thread.
Yes, it is a small gap but if that gap was allowed to accumulate during a glue up, it could become very noticeable. Final assembly can be as important as the individual cuts.reible wrote:One could call that a hairline, seeing as that is what it is.
In reality, many of our cutting errors seem to cancel one another out as we do the assembly. In fact, an experience wood worker probably utilizes that possibility in the process.
