Shopsmith Saw Arbor Set Screw (222458)
I went looking for a set screw with the locking patch to be used in this application.
It may be available but is hard to find.
I got close.
http://www.mcmaster.com/#set-screws/=sh3qv9
Without the locking patch, the sources are many.
I got close.
OR you could use blue loctite.dusty wrote:I went looking for a set screw with the locking patch to be used in this application.
Yes, blue loctite works.beeg wrote:OR you could use blue loctite.
I was looking not because I have a need but because of the needs expressed by other forum members who have arbor screws working loose.
![EEK! :eek:](./images/smilies/eek.gif)
What surprised me was that a 1/4" set screw, with the locking patch, is far less available than are longer set screws.
Consider the wear to the patch created by running the screw in/out.
Consider the breakdown of blue locktite from the same.
Temporary solution to a random problem likely caused by inattention.(JMHO);)
[quote="JPG40504"]Consider the wear to the patch created by running the screw in/out.
Temporary solution to a random problem likely caused by inattention.(JMHO)]
This sorta thing was considered by the design engineer. I am the end user. I now only consider what I need to keep it all running and where to get it and can I afford it.
Side Thought: In the beginning, at the time of the design, I don't believe things like loctite and these patches were even available. That indicates to me that I probably don't need those features to maintain a safe and functional machine.
mumbo-jumbo
Visualize an idealized imaginary setscrew tightened vertically downwards in the arbor.
A setscrew works by pressing its' tip in compression inward against the shaft. This compressive force (call it "C") is resisted by being shared in upward compression along the spiral bottom surface of the tread in the arbor.
The more tread we have from choosing a longer setscrew, the lower the compressive (normal) force per unit area.
The setscrew does not back out immediately due to friction and the resisting friction force is equal to the coefficient of friction for the steel screw on the steel arbor multiplied by the normal force. Since the normal force is less, the friction force holding the set screw is less, but we have more area, so the total friction force remains the same (equal to "C"). So a longer set screw is not more likely to back out.
In the real world, vibration tries to convert static friction to kinetic.
Maybe jpg could convert this rambling stream of thought to something coherent. I have an appointment and just ran out of time!
![Big Grin :D](./images/smilies/biggrin.gif)
![Confused :confused:](./images/smilies/confused.gif)
Peter
- BuckeyeDennis
I think that I agree with that analysis. And you mentioned something that spurred another thought.prmindartmouth wrote:Visualize an idealized imaginary setscrew tightened vertically downwards in the arbor.
In the real world, vibration tries to convert static friction to kinetic.![]()
For a given "compressive force", the holding torque of the setscrew -- i.e. it's ability to resist being back-driven -- is indeed proportional to the coefficient of friction between the threads of the setscrew and of the arbor. Which can vary wildly, depending on whether the screw interface is lubricated, and with what. As in around 10:1.
Dusty, you might want to try cleaning both the setscrew and the mating arbor threads with acetone or denatured alcohol. That will get you a bare steel-on-steel interface, and maximize the coefficient of friction. It may also require you to torque the setscrew somewhat harder in order to achieve the same compressive force.
I'll be very curious to hear if that helps.
Wa2crk [Thanks for the info but I still prefer Grandpa's.
Just for the nostalgia]
But of course you do as would I.![Cool :cool:](./images/smilies/cool.gif)
As for longer set screw, threads interfacing air provide no additional benefit.![Wink ;)](./images/smilies/wink.gif)
Nylok screws were available back in Hans's day!(IIRC) The patch is a low cost alternative.
BD has provided an excuse to NOT wax setscrews.![Roll Eyes (Sarcastic) :rolleyes:](./images/smilies/rolleyes.gif)
![Smile :)](./images/smilies/smile.gif)
