Saftey Caps!!!!!????
reddog5362
Post by reddog5362 »
Ed in Tampa wrote:Actually I think as long as the cap spins the danger (if there is one) is not removed. A hood string would only tighten the cap to the spindle all the more and reel you in.
That is why I work naked.:eek: :D
Note to self..
Do not stop by Ed's shop unannounced.
edflorence
Post by edflorence »
billmayo wrote:Shopsmith made a cover for the 2 SPT shafts that is just what you are looking for.
I ran without safety covers for 5 decades or so on three different Mk V's without incident...don't work naked, as some do, but then don't wear hoodies or neckties in the shop either...finally put a safety cover on the current Mk V but am not going to put one on the new Mini. I guess some peace of mind comes along with the guard, but also some minor hassles. 1) You will need to buy or make some sort of quill twister if you intend to keep the guard on and 2) The guard does not have access to the set screws on the hubs so I had to drill my own holes for that. You have to take the hub off the upper spindle to mount a sanding disk and the access hole lets you do that without futzing with the guard. I suppose you could just leave the hub off the upper spindle but I think I heard somewhere once that the hub acts as a bit of a heat sink for the motor. Don't remember where I heard that.
Idaho Panhandle
"Wild Bad Bob"
Post by "Wild Bad Bob" »
Great points Ed, I will add the holes to access the hub set screw, since I may put the disk on that side on one of the machines.
rbursek wrote:Great points Ed, I will add the holes to access the hub set screw, since I may put the disk on that side on one of the machines.
I think that sanding disk may need to be a 520 version(longer hub).
Speculation, I ain't ever seed one of them 'guards'.
There seems to be additional reasons for not getting one!:rolleyes:
Jack Wilson
Post by Jack Wilson »
I took mine off, just seemed to be in the way.
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
"Wild Bad Bob"
May need to send them back after doing an examination of them!!!
"Wild Bad Bob"
JPG, you do NOT KNOW WHY????
rbursek wrote:JPG, you do NOT KNOW WHY????
'New' reasons were mentioned after my initial post. I had not previously thought of the inability to access set screws and I had forgotten about the new shaft turner!;)
"Wild Bad Bob"
JPG, what is a "threaded pop rivet"? Never heard of one but always learning!!
rbursek wrote:JPG, what is a "threaded pop rivet"? Never heard of one but always learning!!
It is like a 'fat' pop rivet and the inside has threads. It is 'popped' by using a threaded pull pin that pulls the end of the shank that expands at the pulling end using the pop rivet tool. The threaded pull pins are somewhat reusable.
I have not looked for them recently.
