New Look Forum
admin
Re: New Look Forum
Post by admin »
joedw00 wrote:What is this? Sorry, the board attachment quota has been reached.
The reply to post is at the bottom of the post.
The QUOTE a topic is at the top.
Yes, I agree the placement of options is certainly messed up.
I plan to replace some of the important choices with buttons to replace the links and fix the arrangement at that time.
joedw00
Re: New Look Forum
Post by joedw00 »
Here it is what it looks like.
joedw00
Re: New Look Forum
Post by joedw00 »
admin wrote::) The formatting of posting (BBCode) should be ok now and attachments should be fixed.
Thank you
heathicus
Re: New Look Forum
Post by heathicus »
The software update is very welcomed!
I'm not crazy about the theme or style modifications, though. As a couple examples, I can't find the "View New Posts" link, and the reply/quote link being at the top of each message instead of the bottom is not intuitive.
As a workaround, in the User Control Panel and then Board Preferences, I changed my setting for board style to prosilver. Although the color scheme is not "Shopsmith" colors, I like this style much better..
ryanbp01
Re: New Look Forum
Post by ryanbp01 »
For me this is going to take a little getting used to. But I guess change is a part of life.
BPR
beeg
Re: New Look Forum
Post by beeg »
Seems as though I'm going to have to fix the username difference between Shopsmith.COM and Shopsmith.NET. :) :confused: Now after I click on "Submit". I DON'T know WHERE I'll windup, use to be in the same thread, at the bottom of reply's :D
beeg
Re: New Look Forum
Post by beeg »
So after clicking on "Submit" it took me back where I was. BUT said an update was made and may want to revise my reply. Just clicked on "Submit" again.
OKAY, this time it went back to the thread. I'd STILL like to see more than 10 posts on a page.
joedw00
Re: New Look Forum
Post by joedw00 »
After I hit MARK FORUMS READ and then hit VIEW NEW POSTS. It shows the posts that I have read.
admin
Re: New Look Forum
Post by admin »
joedw00 wrote:After I hit MARK FORUMS READ and then hit VIEW NEW POSTS. It shows the posts that I have read.
The two choices are confusing and hopefully someone will suggest a better ways to present them.
The "view new posts" option display posts since your last log-in. The "view unread posts" shows posts you haven't read (which can include posts prior to your last login that remain unread and excludes even new posts that you have already read). Marking posts read changes one, but not the other.
Leaving the site, but neither logging-out nor closing your browser (not just the tab) has been reported on other sites as not resetting your last login time.
Re: New Look Forum
A disturbing(to me) new 'feature' is the lack of attachments displayed within the text as originally created.
Makes much of what I have created less than comprehensible.
Comments re the first pix....
c lock 1.jpg (410.31 KiB) Viewed 2024 times
Comments re the second pix....
c lock 2.jpg (450.67 KiB) Viewed 2024 times
Apparently it is possible to put them within the text. A bit of extra unwanted stuff comes along with the pix. color??? :rolleyes:
The current limit is 1200 x 800 :eek:
Apparently one cannot do them all at once like the previous version. :(
Is there a different limit now? :confused:
This will definitely take considerable getting used to as is. :p
