Le Machine that does nothing . . . .
Re: Le Machine that does nothing . . . .
Le Machine???
Jacob
Post by Jacob »
jsburger wrote:Le Machine???
No, La Machine.
Here is the next addition.
It is by no means finished, but might give you an idea what I am driving at. Those rods will do something and the whole will be 'suspended'.
cranck 1.jpg (55.39 KiB) Viewed 2567 times
More to follow.
rjent
Post by rjent »
No, La Machine.
More to follow.
Nice V6 crank .... ;)
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Jacob
Post by Jacob »
I almost forgot, but there is another gismo.
Along the back wall are two grooves and little blocks that move back-and-forth as well as up-and-down with linkages that connect to a shaft (not shown). The blocks and grooves are tapered (dove-tailed) so they don't fall out.
A video should show that better.
machine 24.jpg (41.85 KiB) Viewed 2504 times
machine 25.jpg (44.01 KiB) Viewed 2504 times
algale
Post by algale »
I'm amazed at your ingenuity! Tell me, do you use your Shopsmith to make any of the parts for La Machine?
Jacob
Post by Jacob »
algale wrote:I'm amazed at your ingenuity! Tell me, do you use your Shopsmith to make any of the parts for La Machine?
When I started this project several years ago I had the Shopsmith and a small drill press. Since then I have added a small table saw and the Shopsmith is mostly used for the jigsaw, disk sander, lathe and a few other operations.
I have all the accessories that the original Shopsmith offered plus lots of spare parts. I described how this came about and details in another section of this forum.
