2 Bearing Quill
jjbuzard
Re: 2 Bearing Quill
Post by jjbuzard »
Some talk here about splines on quills, the quill on the left is from a Gilmer Driven quill, fewer splines, the one on the right is a single bearing quill from a poly V belt drive, more splines, if you want to convert a SS with Gilmer drive you must change the Drive Sleeve Assembly, Idler Shaft and Quill. A friend of mine did this om his 1954 Mark 5.
Quilkl Splines.jpg (784.29 KiB) Viewed 1160 times
rpd
Re: 2 Bearing Quill
Post by rpd »
jjbuzard wrote:Some talk here about splines on quills, the quill on the left is from a Gilmer Driven quill, fewer splines, the one on the right is a single bearing quill from a poly V belt drive, more splines, if you want to convert a SS with Gilmer drive you must change the Drive Sleeve Assembly, Idler Shaft and Quill. A friend of mine did this om his 1954 Mark 5.
There is another option, :)
[youtube]https://www.youtube.com/watch?v=2S7ICFrSttA[/youtube]
Your Gilmer drive quill can be re-machined and fitted with a second bearing by Skip Campbell. MKCtools
jjbuzard
Re: 2 Bearing Quill
Post by jjbuzard »
Good to know.
