and what wood I can in the BMer, 8ft long fits real nice with the passenger seat laid down/back!!!BuckeyeDennis wrote:Then get your retired behind into a truck and drive to Ohio. With a month or so of advance notice, I can fill any reasonably-sized trailer chock full of native hardwoods for a buck or two per bf, and have fun doing it.rjent wrote:Want: Hard Wood, I don't care what
Need: Hard Wood, I don't care what
Cases in point:
http://athensohio.craigslist.org/grd/5646236903.html
http://columbus.craigslist.org/for/5700654818.html
http://columbus.craigslist.org/mat/5712437338.html
P.S. I do not recommend visiting Ohio from December through March, unless maybe you are a cross-country skiing fan. And even then, don't come in March.
ERL will do all the cooking!
What is your one big shop "need" and your one big "want"?
ERLover
Re: What is your one big shop "need" and your one big "want"?
- rjent
You have no idea how I envy that ....BuckeyeDennis wrote:Then get your retired behind into a truck and drive to Ohio. With a month or so of advance notice, I can fill any reasonably-sized trailer chock full of native hardwoods for a buck or two per bf, and have fun doing it.rjent wrote:Want: Hard Wood, I don't care what
Cases in point:
I sold all of my PU's have a couple of 20 foot trailers but nothing to pull them with. I may bring my Motorhome out of moth balls and take you up on that!
Thanks Dennis, I will probably take you up on your generous offer. Keep your eyes open for some nice wood. I really don't know what to even look for species wise, so any suggestion (no you are not pushy
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
ERLover
ROAD TRIP!!!!!!!! Yes I will do the cooking
'Manifold' cooking is not what he meant!ERLover wrote:ROAD TRIP!!!!!!!! Yes I will do the cooking
ERLover
On the BMer V 12, you can set a 5 rib Black Angus Prime Rib Roast, wrapped in Aluminum Foil, on one of the Exhaust Manifolds, in a pan, drive for about 4 hours, perfect Medium Rare, in the summer timeJPG wrote:'Manifold' cooking is not what he meant!ERLover wrote:ROAD TRIP!!!!!!!! Yes I will do the cooking
12 hour shifts on the flight line loading bombs on airplanes and no break to go eat. The MJ-1 bomb lift was the load crews friend. It was known as a Jammer. There was more stuff heated up on the manifold of one of them than anyone will ever know.ERLover wrote:On the BMer V 12, you can set a 5 rib Black Angus Prime Rib Roast, wrapped in Aluminum Foil, on one of the Exhaust Manifolds, in a pan, drive for about 4 hours, perfect Medium Rare, in the summer timeJPG wrote:'Manifold' cooking is not what he meant!ERLover wrote:ROAD TRIP!!!!!!!! Yes I will do the cooking
- MJ-1.jpg (59.1 KiB) Viewed 3356 times
ERLover
'Manifold' cooking is not what he meant![/quote]
[/quote]
You got to love it to do it.[/quote]
I am assuming the planes engine/exhaust not the Jammer??
On the BMer V 12, you can set a 5 rib Black Angus Prime Rib Roast, wrapped in Aluminum Foil, on one of the Exhaust Manifolds, in a pan, drive for about 4 hours, perfect Medium Rare, in the summer timeERLover wrote:'Manifold' cooking is not what he meant!
I am assuming the planes engine/exhaust not the Jammer??[/quote]
You don't get near a jet engine intake or exhaust. An F-16 intake will suck you up in a second. There is a red semi-circle painted on the ramp in front of the parking spot (actually a line like a road stripe) that you don't go inside when the engine is running. The exhaust you can duck under if you are within about 10 feet of the turkey feathers. The crew chiefs do it regularly on their pre launch check with the engine running and the pilot in the seat.
Then you have the end of runway check. The pilot does a final pre flight check of all the systems required at the end of the runway with the crew chief and then the load crew goes in and checks all the munitions and pulls all the safety pins.
The pilot taxies out to the runway, hits after burner and he is gone. You just launched another successful mission.
ERLover
12 hour shifts on the flight line loading bombs on airplanes and no break to go eat. The MJ-1 bomb lift was the load crews friend. It was known as a Jammer. There was more stuff heated up on the manifold of one of them than anyone will ever know.jsburger wrote:On the BMer V 12, you can set a 5 rib Black Angus Prime Rib Roast, wrapped in Aluminum Foil, on one of the Exhaust Manifolds, in a pan, drive for about 4 hours, perfect Medium Rare, in the summer timeERLover wrote:'Manifold' cooking is not what he meant!
I heard, misread maybe, that when they launch with munitions, even not used they are ejected b4 landing. Is that true?
I am assuming the planes engine/exhaust not the Jammer??[/quote]ERLover wrote:12 hour shifts on the flight line loading bombs on airplanes and no break to go eat. The MJ-1 bomb lift was the load crews friend. It was known as a Jammer. There was more stuff heated up on the manifold of one of them than anyone will ever know.jsburger wrote:On the BMer V 12, you can set a 5 rib Black Angus Prime Rib Roast, wrapped in Aluminum Foil, on one of the Exhaust Manifolds, in a pan, drive for about 4 hours, perfect Medium Rare, in the summer timeERLover wrote:'Manifold' cooking is not what he meant!You got to love it to do it.
I heard, misread maybe, that when they launch with munitions, even not used they are ejected b4 landing. Is that true?[/quote]
No that is not true.
