Jigsaw
Re: Jigsaw
Not Boring!
Fer a second I thought you had a racing stripe on the table! :D
Mike907
Re: Jigsaw
Post by Mike907 »
Looks good. How did you make it?
dgreen810
Re: Jigsaw
Post by dgreen810 »
Marked it with a compass, cut it out on a scroll saw, drilled a 3/8" hole, using a brad point drill, run a 3/8" bolt through the hole, chucked it up in my Delta Mini lathe, worked it down to the correct size, using a body file, cut the slit with the scroll saw. It's really neat that you can look down and see what you are doing without looking under the table.
Don G
Re: Jigsaw
dgreen810 wrote:Marked it with a compass, cut it out on a scroll saw, drilled a 3/8" hole, using a brad point drill, run a 3/8" bolt through the hole, chucked it up in my Delta Mini lathe, worked it down to the correct size, using a body file, cut the slit with the scroll saw. It's really neat that you can look down and see what you are doing without looking under the table.
Don G
Even 'neater' with it removed! ;)
dgreen810
Re: Jigsaw
Post by dgreen810 »
Yep!!
Don G
Re: Jigsaw
Don G
:confused: I guess the reason it is removable is so you can remove it to change blades and not have to look under the table.
dgreen810
Re: Jigsaw
Post by dgreen810 »
It's pretty obvious some of you guys haven't done much scroll sawing. Not that this jigsaw is a "Scroll Saw", but the principle is the same making piercing cuts.
Don G
P1010005 (2015_11_11 18_39_05 UTC).JPG (115.28 KiB) Viewed 2704 times
