I think my main table needs to be alligned.
Re: I think my main table needs to be alligned.
dynabase wrote:I don't want to waste anyone's time on this. Bottom line is my system works OK. The sled works and the blade doesn't rub so I'm good for now. After I finish my current project I will do a full alignment and PM on my 520. If I have any alignment issues it should come out then.
Thanks everyone.
Michael
Whatever you say but GOOD LUCK going forward. One of the more hazardous things you can do is operate while needing table alignment.
You weres not talking about thousandths of an inch but rather quarters of an inch.
I doubt doing a table alignment will 'correct' this. There is not sufficient 'slop' in the trunion mounting holes to cause a 1/4" deviation.
i.e. we are not wasting time, we have not discovered the cause yet.
The blade should be close to centered.
BTW does your quill have the rubber stop ring between the retaining ring and the headstock?
