Soliciting ideas for a shop battery & charger system
Ed in Tampa
Re: Soliciting ideas for a shop battery & charger system
Post by Ed in Tampa »
Here is another battery charger/battery storage unit.
https://youtu.be/D1ehymweriI
Well you know how stuff happens..... The place I thought would work would not so I was left with the unit sitting on the floor and getting in the way and it was a pain to have to bend over doing things.
So I set it aside for a while and then just got back to the project. It is not the perfect place but it will work for now. Just finished plugging things in and have two batteries charging as I write this.
It wasn't a perfect fit, it could have been a 1/2" wider but such is life. Yes that is one of my storage units and it is the front of it.
You see it is hinged so it swings open so I can access the boxes.
Now I can go and check if the two batteries are charged, should be as it takes only 20 minutes or so.
