Firefox Problem
rjent
Re: Firefox Problem
Post by rjent »
db5 wrote:This might be a good time to run "Malwarebytes" Did that.
Or check into FireFo help. Did that too.
Also, make sure your clock is correct. If the clock is not in time, it can cause this error. And that.
Even deleted Firefox 57 and reinstalled it. Nothing works.
Try installing (temporarily) an earlier version of FireFox. Let's see if we can determine which software is causing the issue. This can also be a firewall issue or even an Antivirus product issue, but let's start with either an earlier version or another browser completely.
If you want to PM me, by all means ... :)
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
dickg1
Re: Firefox Problem
Post by dickg1 »
Are you using Win 10 and have Windows Defender installed? If so, you might try disabling Windows Defender and see if that has an effect. WD has given me no end of problems with the latest version of FireFox and disabling WD resolved those issues.
Dick
Re: Firefox Problem
P89DC wrote:
JPG wrote:Gotta disagree! Bad assumption!
But then all assumptions are fraught with pitfalls! ;)
I observe far too many 'assumptions' of late that folks do not realize ARE assumptions.
The assumptions are often inaccurate for the issue at hand.
JPG wrote:How about returning to woodworking and SS stuff. :)
touché :)
However I consider 'political' rantings a more severe departure. ;)
