New Project
wasatch
Re: New Project
Post by wasatch »
Depends on how you are going to use it. I'm sure my needs are different than yours. I haven't explored all options, that will come with time and others building and using it too. I just wanted to share it with others on this forum that have helped me when asked.
wasatch
Re: New Project
Post by wasatch »
Slightly modified bracket but works great for refurbishing hand plane iron
ss pic9.jpg (38.31 KiB) Viewed 14240 times
algale
Re: New Project
Post by algale »
I am really liking this jig!
wasatch
Re: New Project
Post by wasatch »
Sharpening an axe
ss pic12.jpg (34.77 KiB) Viewed 14203 times
Tormek XB-100 can also be used on your grinder
ss pic13.jpg (33.79 KiB) Viewed 14203 times
moggymatt
Re: New Project
Post by moggymatt »
Nicely done.
Paul B
rjent
Re: New Project
Post by rjent »
That is absolutely first class work! Just beautiful!
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
videobear
Re: New Project
Post by videobear »
Any chance you could publish a Sketchup file with dimensions?
wasatch
Re: New Project
Post by wasatch »
If you are talking about the grinder mount, the Tormek BGM-100 comes with instructions.
For a simple, straight belt sander mount, purchase the following:
one 1/4" thick 2 inch wide x 13 inch long piece of mild steel flat bar
two 1/2-13 x 8 inch long bolts(cut the hex heads off)
two 1/2-13 nuts
two low profile 1/2-13 cap or acorn nuts
four 10-32 x 1/2 inch long pan head machine screws
one Tormek BGM-100 (comes with bar, around $67)
Use the Tormek base to mark the holes for drilling, then thread with a 10-32 tap
I wrote in a previous post how I marked and drilled the 1/2 inch holes
masonsailor2
Re: New Project
Post by masonsailor2 »
Very nice jig. Love it !
Paul
Re: New Project
wasatch wrote: . . .
Or, just drill the 1/2" holes 7 1/4" c-c. You must be accurate!!!
