joint matic
Re: joint matic
reible wrote:http://www.lhdigest.com/SS/MANUALS/OTHE ... 555458.pdf
VS
https://www.lhdigest.com/SS/MANUALS/OTH ... 555458.pdf
See if your system is happy with the first one. The second one is the one you visited that gave you the error message and FF flagged that all by itself.
The first one opens a new tab long enough to download the file and then closes the tab immediately. About one second. The second one does as I showed above.
edma194
Re: joint matic
Post by edma194 »
Adding some info here for anyone who has the Joint-Matic. According to a recent My Growth Rings video on the Joint-Matic the crank handle used to raise and lower the slide is the same as the one used for the Shopsmith planer. The part identification was noted in this post in a thread about the planer:
chapmanruss wrote: Sat Nov 28, 2020 2:20 pm br549 is correct. So to help eliminate any confusion the height adjustment handle is reference number 27 in the online parts diagram and part number 51413703 as Planer Elevating Crank which is $39.74 plus S & H.
