The original was nylon and required NO lubrication.ceyoung77 wrote:I'm relatively certain that I've gotten everything lubricated according to the manual, but I was wondering what is the best way to keep the variable cam lubricated?
Thanks!
Mark VII on loan
Re: Mark VII on loan
Keep the small bearing in the end of the control sheave lubricated. When that bearing fails the follower over heats and melts the cam.ceyoung77 wrote:I'm relatively certain that I've gotten everything lubricated according to the manual, but I was wondering what is the best way to keep the variable cam lubricated?
Thanks!
Good, however he has a metal cam, hence the question.rpd wrote:Keep the small bearing in the end of the control sheave lubricated. When that bearing fails the follower over heats and melts the cam.ceyoung77 wrote:I'm relatively certain that I've gotten everything lubricated according to the manual, but I was wondering what is the best way to keep the variable cam lubricated?
Thanks!
I simply do not have a definitive answer, but graphite comes to mind(any slick thing that does not like to merge with sawdust).
Okay, thank you. I will try the graphite. I tried 3 in 1 but it seemed to just run off.
I tried to find the post where I think someone mentioned using stick lubricant on the rip fence locks. I by chance got a box of junk from a tractor repair shop that had a stick in it. I finally found it again a couple weeks ago and tried on my Mark 7 fence. I was amazed at how well it worked. It might be worth trying it on a Mark VII with an aluminum cam.
https://www.performanceonline.com/ags-d ... gJixvD_BwE
I found the stick as a result of a Google search and have not bought anything from that particular site. EDIT: The shipping is about twice the cost of the product. It is also available from Amazon prime with free delivery.
This brings soap or paraffin(candle wax) to mind.
