I only have a few pictures with me but ill post them. Im not sure where you got june/july 86 based on the chart. Im not sure what I'm missing. Would Shopshith know more if I contacted them?
I did miss a number. 031888. All the ones in 86 on the chart there have two 0's. In 87 they all start with 01.
year and model of mark v
Re: year and model of mark v
Looks like my directions reading skills need improving. My pictures are over the size limit and dimensions. Hopefully its corrected now...
- Shopsmith model web.png (1.13 MiB) Viewed 2297 times
- Shopsmith 1 web.png (1.06 MiB) Viewed 2297 times
- Shopsmith 2 web.png (1.04 MiB) Viewed 2297 times
- Shopsmith 3 web.png (1.06 MiB) Viewed 2297 times
"03188" is not a date code, but "031888" indeed is especially if it is on a sticker, not the vent plate.
03188 is within the jun/jul timeframe sn sequence.
Now where are the tables?
I didn't take pictures of that yet. I will post later. There are three.
Thank you for the reply. I like this forum.
Three? S/B Four. 1 main, 2 floating(no vertical tubes) and 1 aux. Did you get the connecting tubes and adjustable height poles?Omikay wrote:I didn't take pictures of that yet. I will post later. There are three.
BTW nothing wrong with those last pix!!!!! Indeed very good!!!!
Yes has hieght adjuster feet. Not sure about connecting tubes but I'm pretty sure it does. Who I bought it from dos not use table saw. Only used it for lathe and band saw.
Omikay wrote:Yes has hieght adjuster feet. Not sure about connecting tubes but I'm pretty sure it does. Who I bought it from dos not use table saw. Only used it for lathe and band saw.
These are the legs I was asking about.
http://www.ebay.com/itm/Shopsmith-Mark- ... SwP~tW41Ga
Too Much $$ and incomplete - no right angle coupling and the connecting tubes
