Maybe Castor is Castora?
:: II MK VII = I MK XIV?
Re: :: II MK VII = I MK XIV?
Idler shaft bearings the same as quill bearing. (6202-10 rr) == 5/8" id x 35mm od x 11mm width and rubber seals) X 2 bearings/shaft.
FWIW I think of it as an arrow!!!! The end more closely resembles an arrow point.
Castor been castrated? muuuuuuaahahhahahahhaaa! Russ said it's a 520 carriage, my guess is the 520 doesn't have the post/penis/arrow shaft and latch setup. I had a brilliant idea while I was working on my 1959 Ford tractor. In the back where the three point hitch goes is a top link. It's threaded with one end right hand and the other left hand so it can get longer or shorter as needed for the implement. I might try to use a lightweight top link for the drill press that I can easily spin up or down attaching to the bottom of the table/carriage and the frame below. It could be on a clevis so if needed can be removed completely. This will also provide added support for heavy stock that I'm drilling and pressing down on with the quill.
I just ordered four 6202-10RR for Pollux. Hoping the Mark VII doesn't give me any grief on that. Hey, I was thinking, I could swap headstock motor and get the blower setup on Castor. Wondering if the motor will come out with the headstock on the ways? When I'm in there doing bearings would be a good time to swap if it's not too hard. Really want a vac system on Castor. I might call SS on Mon and see if they have a motor lying around and the vac hardware maybe hidden in a closet in the janitor shack. Maybe
The motor and pan are secured with 4 or five screws. The belt cover needs to be slid back. IIRC, THE SWITCH AND POWER CORD GO WITH IT.
I predict they will say a Mark VII ?????
As JPG predicts if you call Shopsmith and ask for parts specific to a Mark VII they are going to ask Mark VII what???? Then they will ask do you mean Mark 7? Which you do not. Remember the Mark VII was last made in the 1960's and not only by a different company than the current makers of the Shopsmith tools but in a different location with several moves in-between.
I do have to ask why do you want a working dust collection system on Castor since it is going to mostly be a Drill Press for metal? I would understand if you were going to use it for woodworking but sucking up hot metal fragments will only tear up the impeller. As someone who restores Shopsmith back to as new as possible I would want to have all the original parts working but for actual use, I would not want metal going into a dust collection system.
As for your comment about the lowest speed available the Speed Reducer may be the answer and JPG might know if it can be used on the Mark VII. I believe it could but am not positive. That would give you a 7:1 speed reduction.
All SPT's & 2 Power Stations
Speed reducer oughta work. Way/bench tube spacing the same as is the quill fitting.
The only possible difference I thought there could be is the height of the Spindle/Quill above the Way Tubes not being the same as a Mark 5/V.
chapmanruss wrote: ↑Mon Jan 10, 2022 12:15 pm The only possible difference I thought there could be is the height of the Spindle/Quill above the Way Tubes not being the same as a Mark 5/V.
That be the same also.
chapmanruss wrote: ↑Mon Jan 10, 2022 12:07 pm As JPG predicts if you call Shopsmith and ask for parts specific to a Mark VII they are going to ask Mark VII what???? Then they will ask do you mean Mark 7? Which you do not. Remember the Mark VII was last made in the 1960's and not only by a different company than the current makers of the Shopsmith tools but in a different location with several moves in-between.
The Dust Collection built into the Mark VII has everything going through the impeller before being deposited in the bin. Any metal or other "stuff" besides wood dust being picked up will damage the impeller. Even properly used it will wear over time. It is simply not made for shop cleanup kind of work. The Shop Vac deposits what is picked up directly in the container before it can travel through the filter and impeller.
