Obtained a Shopsmith
Re: Obtained a Shopsmith
Ed is correct. That is the old style Miter Guage Hold Down. A previous owner has upgraded to the newer style which is easier to adjust.
The Front Table Extension you have is the correct one. It will attach to both the main and extension tables.
droughton
Post by droughton »
Thanks Ed and Russ!!
As Russ mentioned the front miter slot extension will work on the main and the aux table. You have both the new(wider) and the older(narrow) aux table. Realize it will only work with the older(narrow) aux table if it is readjusted(making it not then work on the main table until readjusted back).
Keep the older miter gauge hold down. It can do things the newer one cannot easily do.
larryhrockisland
Post by larryhrockisland »
JPG wrote: Sun Feb 06, 2022 9:20 pm Keep the older miter gauge hold down. It can do things the newer one cannot easily do.
Got any tips on the old style? I have both but thought the newer one was easier and quicker to adjust.
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
There have been times when it was desirable to use the old style as a clamp for securing the workpiece without having to squeeze the grip thus leaving one more hand available for other endeavors. The knurled nuts provide a way to do that. The new version does not allow 'tightening' beyond the squeeze limit. Also the position locking is more robust.
I agree for 'normal' applications the newer one is a vast improvement.
edma194
Post by edma194 »
I only had the old style hold down to start with. When I got a 510 with the new style I didn't like it at first because I was used to setting the depth on the hold down and using it to clamp down a board early in the setup. But after changing to thicker/thinner boards a few times I realized the new type was a huge improvement and I was only clamping down boards early in the setup with the old style because it was so annoying to adjust for different board thickness later on in the process after everything else was in place.
Has anyone tried replacing the post in the new style hold down with one from the old style so it can function both ways?
Interesting idea Ed. If I understand what you are asking the answer is no. In this case you cannot put a square peg in a round hole. The old square threaded post cannot go in the "U" shaped Lock Clamp (part reference 265) of the newer grip assembly and be locked in place by the Knob. The old square threaded post can go into the Lock Guide (part reference 264) the same as the original one.
edma194
Post by edma194 »
chapmanruss wrote: Mon Feb 07, 2022 11:42 am The old square threaded post cannot go in the "U" shaped Lock Clamp (part reference 265) of the newer grip assembly and be locked in place by the Knob. The old square threaded post can go into the Lock Guide (part reference 264) the same as the original one.
So then, if you really wanted this, and you had the square threaded post left over from an upgrade then it wouldn't be difficult to either drill out the Lock Clamp or fabricate a new one. The key part being that you really want it enough to justify the effort, it only has very limited utility for most people.
Hobbyman2
Post by Hobbyman2 »
One suggestion would be 0- clearance table inserts . you can make them with what you have .or purchase them online , by adding a 1/2 inch arbor you can also use a multitude of blades . JMO I went with a live center when using the lathe, I like the live center better . best tip I have to offer is not to get rid of the carriage or table when or if you upgrade, I have found a multitude of uses for set ups . FYI you can remove the table and carriage turn the headstock around re-install the table and carriage and use it as a router table with the right table insert . I have done this a few times and it works pretty good ,, by adding a sacrificial piece of HDP or wood to the fence will make things easier in just about all cuts , adding a T-slot to the sacrificial fence you can use stops , feather boards and your imagination . but the best advice I have to offer is to be safe and just have fun and enjoy what this tool has to offer . JMO
Ed,
The easiest thing to do would be to simply keep the old Hold-down assembly as shown in the OP's post and with the turn of a single set screw remove the new Hold-down and replace it with the old one for those time you may want the way the old one locks down.
