WINDOWS 11 QUESTIONS
Re: WINDOWS 11 QUESTIONS
Any more I turn to YOUTUBE for everything . if it ever goes away the world will end!!
Can you post the model of the Lenovo? There might be right click function within the touchpad setup in Windows to add this capability.
The touchpad tapping was the first thing I disabled. I tolerate touchpads, but do not find them to be co-operative.
I do not consider the touchpad method to be viable.
An external mouse provides a solution.
BTW I found the three key work around to be laughable. How does one then drag??? I forget the keys, but fn/shift/f10 comes to mind.
I have been a hold out against W11 but after being forced to do a clean install I decided to go for it.
Both the clean install and the upgrade to W11 went well. The desktop format has changed and will require getting comfortable with the changes but that should happen quickly.
Now, I just might upgrade my Surface Pro (laptop) with touch screen)---maybe.
Still under going rehab so I'll not be out in the shop for some time. Rehab tells me at least six weeks more.
GET WELL!!!!
