Up Grades
Ed in Tampa
Post by Ed in Tampa »
woodburner wrote:Hi All,
I for one have always owned a 510 and use it with no problems whatsoever.
I like the fact that you use the large wing handle/lock to bring the fence into alignment before locking it down, as this helps prevent the fence from moving before using the one locking handle that is similar to the 520's fence. The 520 fence has two locking handles, but no wing handle to bring everything into alignment. I think that is why some of the 520 users have problems with movement of the 520 fence when they lock it down. I myself have not had this problem when using my 510 fence.
I did however purchase the Incra system (with router accessories) a couple of years ago and use that fence for most of my ripping now. The fence system itself (without the router accesories) cost just a little more than what you will pay for a 510-to-520 upgrade. If I were thinking about upgrading a 510, I would really consider the option of purchasing the Incra fence first. It is not only more accurate than both the 510 or 520 fences, but you can also add on the Incra router table accesories at a later date if you like.
The main question you want to ask yourself is "how much ripping will I actually be doing?" "Will I be doing enough to justify the expense at this time, or will what I have now do the job I need?" After all, that is pretty much all a fence is used for (ripping).
Depending on that answer, only you can decide on what you truley need. The 510 is perfectly capable doing exactly what a 520 fence can do, and I am still very pleased with my 510 fence after all these years. Sure, the 520 fence looks more modern and has a couple more bells and whistles, but depending on what you plan on making with your system should be your answer.
Since you are just starting out with the 510, give yourself a year with it and see how much you really use your fence. The 520 upgrade goes on sale at least twice a year, so you won't be missing out on anything if you bypass this sale and wait for the next one.
Woodburner
I tend to agree with you on the 510 fence, I actually like it better than the 520 fence. However the 520 is so superior to the 510 in table alignment that I will learn to live with the 520 fence.
On the 510 the floating tables were held in place by a pinch screw that came in from the side. The could pinch high, near the center or low in reference to the connecting tube depending on a multitude of things. On the 520 the table lock in place by pinch screw from the bottom, therefore each and every time they lock in at the same place.
On my 510 I learned to turn the wing nut just enough to move the fence but tight enough to hold the fence parallel. On the 520 using the lever this way is very difficult and almost every time I set my fence I have to lock it, unlock it, bump it, lock it, unlock it, bump it, lock it.
The biggest difference between the 510 and the 520 in my opinion is quality. My 510 upgrade was an absolute mess. The connecting tubes were rusty and discolored, the table rails were simply awful (looked like they spend the winter underwater) my fence was bent and the table was warped. I was not happy. Shopsmith sent me replacement connecting tubes, tables rails and two replacement tables all warped before I finally got feed up, threw all the junk and in the corner and and stopped using the Shopsmith. It sat there basically unused for 10 + years. Then I saw a Demo of the 520, talked to the salesman who convinced me of the superiority of the 520 and I ordered the upgrade. Everything that came was first class quality.
However I still have a warped main table and discolored connecting tubes but hey it is not like a paid a premium price for it .... Hey wait!?! I did pay a premium price. Okay I'll stop my rant. I go off about once a year everytime I think about my 510 upgrade Urrrrgh!!!!!!!
Ed in Tampa
Stay out of trouble!
shydragon
Post by shydragon »
I've been thinking a lot along these lines. Even on sale, it's still $345 with shipping. I've been doing just fine with the fence I have. Are 8 pieces of extruded aluminum and a fence really worth $345. Will it make my woodworking better, my woodworking experience more satisfying. Naw, I think I will pass on this one.
Pat
Oregon
1992 SS 510, 11" Bandsaw on power station, 4" jointer, Pro Planer, Incra Miter 2000, Incra Ultimate Fence Router Pkg, Grizzly 6" Parallelogram Jointer.
flyslinger
Post by flyslinger »
Well Pat, I'll let you know if it was worth it. I just put my order in last night . just couldn't resist . Told my wife "but , but, I need that" she laughs and just says "I know" :)
Hi,
I personally feel this is the ultimate shopsmith upgrade and well worth it. And the purchase can't help but help shopsmith.
flyslinger wrote:Well Pat, I'll let you know if it was worth it. I just put my order in last night . just couldn't resist . Told my wife "but , but, I need that" she laughs and just says "I know" :)
toolcollector
Post by toolcollector »
I have an '83 500, converted to a 510 when it came out, then converted to a 520 when that came out. The conversions are pricey, but the improvements are worth it. I do think the 510 to 520 conversion is overpriced, but you can't get it anywhere else so I purchased it.
Maybe it's the wrong way to use the fence (concerning movement) when clamping it down) but I slightly engage the rear (Top) clamp, then engage the front (bottom clamp) and then fully engage the rear - works for me, stops the movement and sets the fence were I want it.
'83 500/520, '54 500 Greenie, Shopsmith Power Station, Planner, Jointer, Belt Sander, Strip Sander, Scroll Saw, Bandsaw, Jigsaw, Lathe Duplicator, Router Table, Dust Collector & Dewalt Dual Compound Sliding Miter Saw.
wa2crk
Post by wa2crk »
Hi Gang;I have the 520 system and I do not have a problem with the fence. At one of the SS travelng academies Susan Reid ( one of the best instructors they had) explained how to set the fence without it moving.
First set the fence into the approximate position and then just snug the bottom handle just enough to hold the rubbing blocks on the fence to the front of the rail and then release the handle. Then place your right hand on the casting of the fence and keep slight pressure against the front rail while you move the fence into position. When you then tighten the lower handle the fence will not move, (should not move). After you do this several times you will find yourself not having to use the lower lock on the fence because you will develope a "feel" for the fence and you will be able to hold it against the front rail and move the fence anywhere you want.
Bill
[quote="wa2crk"]Hi Gang]
Yup, works great!
flyslinger
I just got my new fence system this past week and can already tell from my brief use its just what I wanted , the upgrade was easy and didn't take long at all. Havin read previous messages about the fence moving, it was the first thing I looked at , and using my hand to hold the fence is exactly what I did and I light pressure on the bottom lever and no movement at all.....and the solid locking on the off feed side is great. Guess I should have just bought the 520 from the start, but then the only upgrade would have been the 530 :)
