To set your miter gauge to 37.2° with the Standard Miterset do this.reible wrote:Hi,
The problem comes with the way these things work. With a wixey inclinometer or my preferred beall tilt box it has to stand to work. Picture tipping it over on its back and then trying to use it to determine angles. It just doesn't work that way.
I have to measure in that horizontal plane, so I need something that is a protractor to do what I need to have it do.
Protractors also work like the tilt boxes because they are still just measuring an angle.
So if you wanted to say set your miter gauge to 37.2 degrees, with a tilt box you would have to hang the miter gauge with the head down and keep miter bar in place. Zero the box to the miter bar then sit it on the head of the miter gauge and adjust it to 37.2 deg. However a protractor you would use on the table with one leg on the bar and the other on the head and adjust to 37.2 deg.
Does that make since? I can do up a sketch if not....
1. Set the pins of your MiterSet to 35°.
2. Add 2° to this setting with the detent bar, giving you a setting of 37°.
3. Add a shim .0175 thick between the detent bar and the 00 pin, which will add .2° to your setting of 37°, making the total 37.2°.
This is the first time I have shared this operation with anyone, so I will explain how it works. The holes in the “Standard” Miterset are drilled on exactly a 5-inch center-to-center distance. At this radius one degree is approximately .08726 inches. Multiply .2 times .08726 and the product is .0175. For most applications you can round off to either .017 or .018 and use a regular feeler gauge for your final amount.
Remember the base number .08726 is equal to 1 Degree on the “Standard” Miterset, and you can come up with almost any setting you need.
Good Luck
Dick Pattee, Inventor of Miterset
